Loose gase cap symptoms?
The other day I started my 85 L98. It started fine. I drove to the mail box and left the engine idling. When getting back in the car and trying to accelerated the engine rpm would not respond. I was able to limp back to my home in idle. I shut the engine down and it would not restart. The check engine light was on. I checked the gas cap, as I had recently filled the tank, and found it was not completely tight. Tightened the cap. The next day I started the engine and it ran fine, although I did not drive it. I let it warm till both coolant and oil temps came up to normal tempts. Was able to give it throttle and the rpm's responded normally. It ran fine. My question is, could a loose gas cap cause this symptom?
Thanks,
JW
Thanks,
JW
I don't think it can. It has very little to do with anything except throwing a code on OBD2 cars which you do NOT have.
Received 1,404 Likes
If the SES light was on, pull the code and tell us what that was.
Thanks vader and aklim. Because of my circumstance, it's going to require a tow to my mechanic. I can't trust the car to make it on it's own giving to the lack of reliability and my physical condition
JW.
JW.
6 months ago I went through a brushless car wash with my 85. After the wash I drove to the grocery store. Got back in the car and it started fine but a few minutes latter it started backfiring thru the intact. Limped the car back home. Next day I started the car and it ran fine and I had no further recurrence of the problem. Last week I got caught in a rather good rain storm. Short time latter the same problem occurred. Limped the car back home. Got in it the next day and once again it ran fine. Obviously, the problem is water getting to an electrical component and drying up by the next day. I don't think its the distributor as I have been through the same car wash since the first problem but have shut the engine down during the wash and have had no problems.
So, my thought is water is being sucked into the intake and contaminating an electrical connection. Any of your thoughts would be appreciated.
JW
JW
