If you could pick anything for your C4...
Are you racing enduro?
To be honest, the only mod I did for my 1996 C4 was upgrade to a 2000 C5 FRC.
But if you haven't done so already, I did see a lowered C4 and it looked really good.
Id send my whole car to Haibeck Automotive Technology and have him go through the car front to back top to bottom, coil overs, a 4:10 rear gear set, and and this engine package:
415 Cubic Inches, 650 HP
- Four inch liners with Diamond pistons and Molnar rods
- 4.125” stroke Bryant crankshaft. 4340 steel material.
- Maximum porting. The plenum port septum is removed.
- Large intake valves
- Long tube headers
- Fidanza aluminum flywheel
- Extended duration camshafts, choppy idle.
- If driven well, this engine will run 10.9 @ 130 mph in the quarter mile. For use at the drag strip a high torque capacity clutch is required. It is not included in the engine package.
- Long tube headers
Wait.. Are you saying someone has already mounted a 22 gallon cell in the back of a c4 safely ? And, what's enduro racing, unless its on a motorcycle.
- Long tube headers
- Long tube headers
Should be able to run faster than that shouldn't it? My 84' ran an 11.5 @ 120 (best MPH that day being 123). I think I could get a low 11 out of her with sticky tires. I'm pretty sure I'm around 400 wheel, 3.73 gears. 275/40/17 Nitto NT05 tires. Car doesn't have any weight reduction minus a missing AC system.
And Enduro is Endurance racing. Usually a minimum of 7 hours. But up to 24.
#34
Enduro is short for Endurance Racing.
#35
Yes, first done many years ago for racing, designed to pass SCCA W@W tech inspection. The factory tank isn't up to the safety regulations. Fuel Safe offers a service to modify the factory tank, add bladder, etc. However that service is much more expensive than going the route of the 22 gallon cell, and you add 2 gallons.
#36
It is actually quite a famous painting, and I like it. Not much else to say except that it has a real effect on many people, which is probably why its so well known.
v8vette84 (02-26-2019)
#39
After looking at the C-4s for 20 + starting to like the body style . I went over to look at a friends 96 with a LS installed in it looked factory 500HP 6-speed runs and drives like new C-4 . I want a LS in my 93 ..
#40
I want a tough, rebuilt 700R4 transmission and a Dana 44 rear end.
