Belt size with eliminator kit.
Some kits say you can use the same belt but I had to get one an inch shorter. Best bet is to wrap a string thru with tensioner depressed and measure it. Most stores will take belts back if you dont get them dirty so buy a couple different if your stock one doesnt fit then return the ones that didnt.
