brake booster
Hello Cliff, looks like I am definitely going to have to make a booster change on my 86 as I have a hard brake peddle and very little brake response, can you give me any tips on making this change, also is it possible that I might only have a bad check valve? Thanks in advance.
Brake Booster
Thanks 4 your reply, other post I have read said they are a real PITA to replace, did u have that problem? also did u replace with plastic or go to steel?
I have the 85 and if you take the seat out it helps alot. Also if you put ducktape on the metal plate that is in there it will hold it so your screws will line up. Otherwise the plate can slide and aligning is tough when trying to get the screws in.
Good Luck
Good Luck
