Genssi LED Projector headlights in 85
Old 04-19-2017, 05:12 PM
85 Stalker
85 Stalker's Avatar
Default Genssi LED Projector headlights in 85
One down one to go. I thought my existing headlights were acceptable, but after seeing the test in the garage to compare the two -- wow
I was a little nervous spending this much money on the lights without seeing them and was pleasantly surprised with the quality of the Genssi lights. If you are on the fence with doing this converesion, do it
I'm going to align them 40 feet out. With people running projector lights, is this adequate?
Old 04-19-2017, 05:24 PM
C5 4me
C5 4me's Avatar
I got a set,Its like night and day!
Old 04-20-2017, 10:24 AM
85 Stalker
85 Stalker's Avatar
I have something weird -- the high beams stay on all the time. It is not the switch because the other OEM bulbs respond to the hi/low switch.
FYI - I'm using their SPI resistor.
The pigtail (yellow/black) is not being used, since there is nothing to plug in to. Does the pigtail need to be used?
Unfortunately there is no help line number for Genssi....
Any ideas / suggestions?
Old 04-20-2017, 10:40 AM
C5 4me
C5 4me's Avatar
I don't have this problem? you might wanna try these,I haven't had time to install them,but at this price its worth a shot.Its a simple plug and play install.
https://www.superbrightleds.com/more...lbs/2179/5079/
Old 04-20-2017, 11:14 AM
TorchTarga94
TorchTarga94's Avatar
They're great
Old 04-20-2017, 12:13 PM
85 Stalker
85 Stalker's Avatar
Originally Posted by TorchTarga94
They're great
Beautiful car!
I have those exact resistors from SBI. Where did you plug the yellow and black plug tail in to? My lights have the H4 and the pigtail. At the moment I have that two wire lead taped.
Old 04-20-2017, 12:29 PM
C5 4me
C5 4me's Avatar
I wish I had mine installed,That way I could help you answer your question. Mine got lost in shipping & they had to send me another pair. I just haven't had any free time because I am in the middle of moving.
Old 04-20-2017, 12:39 PM
aklim
aklim's Avatar
Received 2,254 Likes on 1,960 Posts
Originally Posted by 85 Stalker
Beautiful car!
Nowhere. They are in case you want to use the DRL.
Old 04-20-2017, 12:41 PM
85 Stalker
85 Stalker's Avatar
Any clue why the lights remain in hi beam only?
I did a web search and cold not come up with anything.
Old 04-20-2017, 12:42 PM
aklim
aklim's Avatar
Stupid question but HOW EXACTLY did you tape them up? I trust they were taped up SEPARATELY and not together?
Old 04-20-2017, 12:45 PM
85 Stalker
85 Stalker's Avatar
I put a rubber connector cap on male terminal secured with electrical tape then covered with FlexSeal black tape.
aklim
aklim's Avatar
So the leads are NOT touching each other?
Old 04-20-2017, 12:47 PM
aklim
aklim's Avatar
Genssi: (702)-988-6800
Old 04-20-2017, 12:53 PM
85 Stalker
85 Stalker's Avatar
Cool - thanks for the number, I'm going to call them now. The pigtail wires are definitely not touching.
Old 04-20-2017, 01:13 PM
85 Stalker
85 Stalker's Avatar
Just got off the phone with their customer service -- very responsive. They are going to email a troubleshooting guide.
He had me check the H4 pins, he said sometimes they are out of order (left and right flipped) -- mine are correct.
Just waiting for the email guide.
Old 04-20-2017, 02:22 PM
85 Stalker
85 Stalker's Avatar
I did the bench test they recommended. They suggested I return the bulbs as it looks like they are not compatible with the 85 wiring.
That sucks - I fell in love with these........
Old 04-20-2017, 02:27 PM
TorchTarga94
They're compatible. Just plug in the H4 Harness and use the circuit doctor method to keep the electronics happy.
To Genssi LED Projector headlights in 85
Old 04-20-2017, 02:54 PM
85 Stalker
85 Stalker's Avatar
I temporarily tied in a 12v bulb and that did not resolve it either.
I went with the 6ohm resistor in lieu of cutting the wires, the support guy at Genssi had me do the various wire tests and double checked the pins to make certain they are aligned correctly.
It is a blast turning wrenches, but I HATE electrical.
Old 04-20-2017, 03:27 PM
85 Stalker
85 Stalker's Avatar
circuit doctor procedure
I think I'll pick up a couple H4 extension cables and tie in 168 bulbs to both lights at the same time and see if this works. When I did my earlier 12v bulb test that was only on one light, it may have not been enough load on the sysem.
I do not want to cut into the new GENSSI light wires or the harness. The extension cable will be perfect for the test.
Old 04-25-2017, 05:04 PM
85 Stalker
85 Stalker's Avatar
I did the "Circuit Doctor" fix with the 168 bulb tied in and everything is working perfectly
Now I'm waiting for it to get dark so I can dial them in against the garage wall. I have the car backed up 40 feet. At 40 I'm going to have it so the projector light low beam line breaks about knee level (at the wall).
Is this the best way to do it? Any suggestions
Low beam before alignment
Hi beam before alignment
lo beam
Hi beam
Quick Reply: Genssi LED Projector headlights in 85
