Wipers. Turn off problem.
A lady friend took her '96 LT4 for inspection today and when they went to turn the wipers OFF, they wouldn't stop unless you turned the car Ignition off. After that, they will park and remain off. What should I look for when I see her car? Stalk switch contact problem or is there any park contacts in the motor housing that need to be checked?
I had the same issue but intermittent. The wipers would run till I shut the car(1989) off then they'd park. What I tried and it worked was: I pulled the end of the wiper motor off that has the circuit board on it. I cleaned the whole thing with contact cleaner. You could use Deoxit, MG Chemicals Super Contact Cleaner...any product like that. So I sprayed the assembly, circuit board, micro switch that was on the board several times. I lightly blew off the excess with my compressor and set it aside to dry. Then I put it back on the motor. It has worked without a hitch since then. Someone had told me there was a "park" micro switch that gets gunky and a cleaning might fix it. I really didn't have the $$ for a replacement part right then. I have found the contact cleaner to be an invaluable addition to my "tool box."
Went
Went
Went
Went
Went
Went
Your problem is the circuit board or brain or the rear of the wiper motor. It is easy to remove qnd in my case replace. There ere new and febuilt ones, as well as
used.
I got one from Jason at Vette2vette and as always works great. Mine had lost its mind completely.
It takes 2 minutes tu change and is thankfully fully accessible. One of the commonl faults of a 96.
used.
