Rear Hatch Latch
Rear Hatch Latch
My latch that attaches to the rear glass is starting to wear out. The plastic coating that goes over the metal latch is falling apart - which is causing the hatch not to shut or open properly. Has anyone had any luck finding a new replacement? All I have found so far is used options on ebay. I have a 95 vette.
Thanks for any suggestions.
My latch is in similar shape. My plan when I get around to it is remove the latch assembly, remove old plastic, buy a can of plasti dip (the can you actually remove the top and dip things in not the spray) and dip it a couple of times.
