Couple Questions
Old 02-22-2017, 04:39 AM
SuperDave02
SuperDave02's Avatar
Default Couple Questions
Will these wheels fit a C4? https://losangeles.craigslist.org/la...013547526.html
Second. What size rivets are used on the outer window sweep?
Old 02-22-2017, 08:53 AM
cormorant71
cormorant71's Avatar
I can't help you with the tires, we need more information. The OUTER sweeps don't need rivets. They have small tabs that slide onto a metal ridge in the door. Use a soft rubber mallet to help.
The INNER sweeps however, I have used 3/8" aluminum rivets to secure it to the door panel. I hope this helps.
What year C4? Mine was an '88...
Old 02-22-2017, 09:22 AM
kael
Support Corvetteforum!
kael's Avatar
Finalist 2020 C4 of the Year - Unmodified
List of all wheel sizes for various years:
http://www.mirrockcorvette.com/corve...de-wheels.html
Old 02-22-2017, 09:34 AM
Jeffgett
Jeffgett's Avatar
The outer door sweeps do require the use of three 3/8 rivets to secure the outer sweep..which have to be carefully removed to release the old outer sweep...I just did mine about a month ago in which the tabs lock into the channels you will then secure the sweep with rivets. I have attached a pic that shows 1 of the three rivets..
Old 02-22-2017, 09:40 AM
cormorant71
Thanks for putting that pic up. I did mine a few years ago and I couldn't remember nor find the pictures... that makes sense now.
Thanks!
Old 02-22-2017, 04:16 PM
billschroeder5842
Zen Vet Master Level VII
billschroeder5842's Avatar
Received 1,143 Likes on 846 Posts
Hint: Put a dab of fresh silicone gel behind the rivet just prior to drilling. When you drill the outside off, the back part of the rivet will fall into the gell and stick.
There is no way to get your fingers behind the frame and if you don't get those little buggers they will rattle in your door.
To Couple Questions
Quick Reply: Couple Questions
