Just curious. Who has their original Optispark?
Old 08-28-2016, 09:33 AM
Atomic6
Atomic6's Avatar
Default Just curious. Who has their original Optispark?
I owned a 1996 Firebird Formula for nearly 10 years and 40,000 miles and never had an issue with the optispark. I bought it new and it was garage kept with basically no repairs ever needed. Now owning a '96 Corvette w/ 29,000 miles makes me wonder what's ahead. It's also all original with few repairs over it's 20n years. Who has their original optispark still? How many miles on your car? Is age affecting these optis or is it the miles? Any pattern shown or is it 'luck of the draw'??
Old 08-28-2016, 09:44 AM
charliet615
charliet615's Avatar
I have a 93 with the original Optispark and 67k miles and still runs strong. I believe it is the "Luck of the Draw" and how it was taken care of. IMHO
Old 08-28-2016, 10:06 AM
ColaBear
ColaBear's Avatar
2018 C1 of Year Finalis4
I have a 96 LT1 with 92k and it still has the original Opti. I have replaced the cap and rotor with a new AC-Delco unit.
Old 08-28-2016, 10:25 AM
Mr Angry
Mr Angry's Avatar
I had the original Opti on my '94 Z28 until I was ready to sell it. 150k miles, and I was not nice to it. Put it up for sale, and it started acting up.
I did, however, take it apart when I had the water pump fail at 80k. I cleaned it up, loctite on the rotor screws, and silicone sealed the cap (a few old tricks from the F-Body guys that seem to really extend service life).
We just did the Opti on my buddy's '95 Vette, at 180k miles. It was original, too, aside from a cap and rotor change at 110k.
Old 08-28-2016, 10:26 AM
Mr Angry
Mr Angry's Avatar
The 3 biggest killers are
1) Water pump leak. The weep hole is directly over the opti. When we change water pumps, we always do the weep hole mod. Tap it, put a fitting in, and run a small rubber hose down past the Opti.
2) Leaking front intake seal. It gets oil all over the Opti.
3) Rotor screws coming loose. Loctite them, good to go.
Old 08-28-2016, 11:36 AM
antfarmer2
antfarmer2's Avatar
I still have mine in a box. I changed mine at just under 100k before I knew better. I was doing the plugs and wires before a long trip. I was told it was a good idea to change it. So glad I saved it.
Old 08-28-2016, 12:00 PM
B17Crew
B17Crew's Avatar
59,000 miles on my current ’96, no issues. Had a ’94 coupe that I traded for my ’96, had over 66,000 miles on that one. No issues with that one either.
However, I bought a new ’93 off the showroom floor. At 9,000 miles, the opti went, it was covered under warranty.
B17Crew
Old 08-28-2016, 10:03 PM
gdl2165
gdl2165's Avatar
My 96 just turned over 140,000 miles. Original opti with a new cap and rotor when I did a cam change at about 120,000. When I took it apart I found one rotor screw had fallen out and the other one was loose, I'm surprised it was running fine at the time. I actually made the mistake of replacing the opti with an AIP unit while I was doing the cam. That one was crap, it would cut out at anything over 5,000 rpm so I ended up putting the stocker back on but used the cap, rotor, and harness from the AIP. Interesting note there, the AIP harness recently developed a problem, I had one instance of a low resolution signal loss and the car just shut off. A few other times recently I'd noted an occasional miss during moderate acceleration. I was afraid my original opti was on its way out but I spent some time looking at the wiring first and found that the wires on the harness were showing some signs of being affected by heat. I put the original harness back on, even though the locking clip on the opti end had broken off, and it's been running perfectly for two weeks now. I'm concerned about the broken lock clip so I've ordered a new harness from EFI Connection.
Old 08-29-2016, 12:03 AM
Whiteonrice
Whiteonrice's Avatar
My 95 has the original but the car only has 22k miles on it
Old 08-29-2016, 11:03 AM
Atomic6
Atomic6's Avatar
Thanks for all the replies. From replacing when almost new to 100,000+ miles use with no issues. That's running the full gamut. I'm certainly not seeing a pattern develop so it may just be 'luck of the draw' so far.
Old 08-29-2016, 04:29 PM
DGXR
DGXR's Avatar
1995 LT1 65,000 miles all original and no issues.
Planning to change the plugs and wires soon, no driveability issues but 21 years is long enough.
Old 08-29-2016, 07:29 PM
Tom400CFI
Pro Mechanic
Tom400CFI's Avatar
Received 3,181 Likes on 2,322 Posts
You got it. As I said in another thread;
Originally Posted by Tom400CFI
Life span: Between 0-200,000 miles.
Symptoms before failure: Range from no symptoms before failing, to the following "warnings": idle miss, lugging miss, high RPM miss, hard starting, random miss, no miss, but CEL....
I'm not joking; the life span and symptoms run the gamut. You could get/see anything. My original lasted over 150k, then started with a low RPM/lugging miss, then a high RPM cut out, and finally, "died when hot". Others have seen all manners of failures, and all ranges of miles.
Mine went 155k.
Old 08-29-2016, 07:39 PM
93droptop
93droptop's Avatar
The original on my 1993 vert went 100K, over the next 50K I lost 3 optis. The worst one only lasted a couple days (cheap Chinese unit). I Added a vacuum line to the current AC Delco unit and have had about 10K trouble free miles.
Old 08-29-2016, 08:22 PM
Turbo Bob
Turbo Bob's Avatar
Corvette Challenge Champ-01
Dragster Challenge Champ-06
Just recently purchased a '95 coupe. Optispark is original. 43k miles. Plugs and wires have been changed.
Old 08-29-2016, 08:43 PM
Edv92c4
Edv92c4's Avatar
Mine is original...1992 coupe...and it should be at only 15,400 miles...runs great!
Old 08-29-2016, 10:40 PM
JBRUSS
JBRUSS's Avatar
I have a 96 Grand Sport Coupe with 27,000 miles or so on the original optispark with no issues.
Old 08-29-2016, 10:51 PM
jess
jess's Avatar
My 95 vette has 247,000 miles with original Optispark. Engine is original never rebuilt
To Just curious. Who has their original Optispark?
Old 08-30-2016, 09:24 AM
QCVette
QCVette's Avatar
My LT1/LT4 cars with Optispark:
'96 42k Corvette (current)
'95 44k Corvette (current)
'96 110k Caprice (current) (water pump failed)
'94 145k Corvette (sold in '11)
'94 35k Corvette (sold in '95)
'95 54k Z28 (sold in '01) (water pump failed)
'96 115k Impala SS (sold in '03)
'95 140k Caprice 9C1 (stolen in '05)
All of these were original and I never had any problems with them even with water pump failures leaking on them.
Old 08-30-2016, 03:50 PM
AllGensAdmirer
AllGensAdmirer's Avatar
Location: Saratoga Springs, New York (Trinity, Florida January through April)
Ditto!
Old 08-30-2016, 05:10 PM
jph46
jph46's Avatar
My 93 went 67,000, what got it was a failure of the water pump rear bearing.
Quick Reply: Just curious. Who has their original Optispark?
