1989 hatch weatherstripping
Old 03-31-2016, 12:10 AM
Went
Went's Avatar
Default 1989 hatch weatherstripping
Today my hatch weatherstripping broke loose. I've bought Willcox weatherstripping for the rest of the car. They price the weatherstrip for $70...everyone else is a bit pricier. ZIP Corvette is $100 for example. Is the Willcox hatch weatherstrip pretty good? Reasonably easy to install? I'm going to break out the cover...this is a daily driver and its supposed to rain this weekend here.
Old 03-31-2016, 06:39 AM
kenmohr
kenmohr's Avatar
Originally Posted by Went
Today my hatch weatherstripping broke loose. I've bought Willcox weatherstripping for the rest of the car. They price the weatherstrip for $70...everyone else is a bit pricier. ZIP Corvette is $100 for example. Is the Willcox hatch weatherstrip pretty good? Reasonably easy to install? I'm going to break out the cover...this is a daily driver and its supposed to rain this weekend here. Thanks
My experience with imports has been poor. They don't fit properly in the corners and split at the seams quickly. Found http://www.steelerubber.com/ fits perfect and it has been years with no problems. Bad news $180.00. If you are fussy you will be pleased.If you are not fussy Wilcox is nice to deal with.
shootnstarz (03-31-2016)
Old 04-01-2016, 03:41 PM
Went
Went's Avatar
Are the corners on the Steel Rubber product bonded really good? A photo on the their website wasn't encouraging. I know a photo doesn't always tell it like it is...but I think maybe they should have posted a better photo. Willcox's weatherstrip is $70, Steel rubber $180. Are they that muck better?
Thanks, Went
Old 04-01-2016, 04:40 PM
Dt86
Dt86's Avatar
My Wilcox after about a week.
Old 04-01-2016, 05:41 PM
Went
Went's Avatar
Are the corners on the Steel Rubber product bonded really good? A photo on the their website wasn't encouraging. I know a photo doesn't always tell it like it is...but I think maybe they should have posted a better photo. Willcox's weatherstrip is $70, Steel rubber $180. Are they that much better?
Thanks, Went
Sorry to pester you...did you glue your weatherstrip down? Some movies I've seen just shows the weatherstrip being snapped down over the lip.
Thanks, Went
Cruisinfanatic
Support Corvetteforum!
Cruisinfanatic's Avatar
Location: Clifton Park, NY ..............Clearwater, FL ... 85 Original Owner
My Wilcox after 16 months
Went (04-01-2016)
Old 04-01-2016, 09:02 PM
antfarmer2
antfarmer2's Avatar
I got mine off ebay about $65 and still good five years latter just a crap shoot. No glue I set the corners first then found the middle on top and back then found the middle again on each and worked it in easy job. Just be careful taking the struts off.
Old 04-01-2016, 09:56 PM
Cruisinfanatic
Thanks, Went
rear is never glued
Old 04-01-2016, 10:13 PM
antfarmer2
antfarmer2's Avatar
Originally Posted by Cruisinfanatic
rear is never glued
I sure hope not!!!
Old 04-01-2016, 10:56 PM
85vetteguy
85vetteguy's Avatar
I used the one from Willcox. It separated within 2 weeks. It is crap. I will pay $180 if I know it won't split. I spent 3 hours installing this only to be back at square one. The new one looks no better than the old one did. I'm very upset.
Old 04-02-2016, 12:26 AM
Went
Went's Avatar
So I'll order the Steel Rubber weatherstrip and see how it goes. Hopefully the extra cash is worth it in the long run. My '89 is a daily driven car. It rains a fair amount here in Oregon during the fall/winter/early spring.
Thanks, Went
Old 04-02-2016, 12:37 AM
Went
Went's Avatar
Well, the Steele Rubber weatherstripping is ordered. It will be here in 3~6 days.
Went
Old 04-02-2016, 04:59 AM
kenmohr
kenmohr's Avatar
Went
I sure you will be pleased. If you have a problem they will correct it promptly.
I had 3 imports on and every one split within 6 months. None fit in the corners properly. This one has been on for I think 5 years. Make sure seal is warm it will be easier to install.
Old 04-02-2016, 05:02 AM
kenmohr
kenmohr's Avatar
rear is never glued
No Glue
Old 04-02-2016, 08:23 AM
Renfield
Renfield's Avatar
The corners were a bit loose on mine when I bought it. Then when I took it back to the tire shop to have them remount the saw blades they installed backward, one of the guys tore the loose corners out for me. No extra charge!
If you're ever in Laurens, SC, I can tell you which tire shop to avoid.
Mine too is a daily driver. But I have covered parking at both ends of the journey. So no new rubber there yet.
I did the window frame rubber though and now the window doesn't meet up with the groove.
Old 04-02-2016, 08:34 AM
PatternDayTrader
PatternDayTrader's Avatar
Received 1,056 Likes on 769 Posts
So I take it that weatherstrip is no longer available from Chevrolet ???
Old 04-02-2016, 11:53 AM
DinoBob
DinoBob's Avatar
Absolutely not.
To 1989 hatch weatherstripping
Old 04-02-2016, 12:22 PM
Dt86
Dt86's Avatar
I wish. Most aftermarket is junk unless you get lucky and get a piece that fits right and doesn't rip or deteriorate in a year or two.
Old 04-03-2016, 05:38 AM
kenmohr
kenmohr's Avatar
Steel rubber got the specs from GM. Made in the USA
Old 04-14-2016, 03:13 PM
Went
Went's Avatar
Yesterday the weatherstrip arrived. I plan to install this weekend. Any sage advice for me? No glue...anything else?
Thanks, Went
Quick Reply: 1989 hatch weatherstripping
