wheels
wheels
Do they produce any descent 16 inch wheels for a 1984 Vet,I need new tires and I want to keep everything standard,just want a different style wheel.
I think ARE wheels make TorqueThrust wheels in 16 inch width to fit C4 Corvettes, check their website, I have ARE 398 wheels but they stopped building them many years ago.
255/50R16 BF Goodrich Sport Comp 2's can be had for as low as $135, Toyos a bit more. That's about it for reasonably priced 16's.
As above, for the long term, go with 17's....1991 to 1996 Sawblades are a great factory C4 choice, but the Subaru, BMW, VW, fart can crowd will be looking for them as well.
For an '84 specifically there might be a greater value in moving to the 17" product. I'd think that ride quality could certainly be improved using the "newer construction technologies" of more recent tires.
I don't believe there could be any that might argue the 16" replacement after-market wheel vs. 17" wheel/tire combination.
Price? I'd think maybe the 17" even less expensive.
You should go to the 17s for sure. I have a pair of Kumho 275/40/17s (new) that I have on another car. They are just a little too low profile for it but I think they will fit nicely on my 91 vert. I got them on sale for around $100 apiece. They have about a 10 inch tread. I see that profile sold close to that price often. If you are getting new wheels anyway, you could also open up the possibilities for larger rotors/calipers if you wish. You definitely are in a win/win situation. You should make sure your off set is similar to the wheels you have so the suspension geometry is good.
Good luck,
BTW: Seeyouinajif has a set of 17s available on his active thread right now. You might be able to work out a deal. I forget the name of the thread but it's on the first page now.
WEK
Good luck,
WEK
seeyouinajif (02-22-2016)
Good luck,
WEK
Good luck,
WEK
