New Video 84-96 Corvette Rear Hatch Weatherstrip Installation
Former Vendor
Received 1,813 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
84-96 Rear hatch weatherstrip installation.
Former Vendor
ttt
Former Vendor
We do about 5 to 10 of these a year and we always try to center it first. The reason I say this.... There are variances between manufacturers in the weatherstrips from corner to corner so getting it as close to center first is best. If you get close to center the movement needed to obtain a perfect fit is minimal.
Former Vendor
ttt
Nope.. you don't want to do it that way...
Other problem with starting in the middle, was that the corners wouldn't fully seat into the channel. You would press in the corners, and they would pull back out some.
Though the last one I installed didn't have any grease inside it like the ones from before. But the last one I installed, I first pressed the corners in and worked towards the center. It was a breeze. Also I found the corners were still pressed all the way in afterwards.
Former Vendor
I value your opinion but I humbly have to disagree. I guessing you have never installed a GM weatherstrip where putting it in the corner first would not even be an option. If you installed the GM that way you'd run out of weatherstrip because the GM was about 65.5" from corner to corner.
I've never had a problem measuring it to get it "close" and you can slip the halo section left to right to make slight adjustments once you see where it's at. Instead of using a tape measurer fold the weatherstrip in 1/2 to find the approximate center, you’ll have better luck.
I can't advise anyone to start in the corners and if you look at other published installation instructions all will tell you to start in the middle. One video I just looked at tells you to start at the back on center which is something I'd also never do. You might get lucky starting in the rear a couple of times but like I stated, you don't want to "Monkey around" with the rear corners so moving the weatherstrip would be more difficult if you missed it on center starting from the rear.
Other installation instructions can be found at the following links:
http://repairs.willcoxcorvette.com/1...-installation/
http://repairs.willcoxcorvette.com/1...nother-vendor/
Regards,
Willcox.
Regards,
Willcox.
Former Vendor
ttt
Former Vendor
ttt
Former Vendor
ttt
Former Vendor
Ttt
The most important tip I would give anyone attempting this, is to let the weatherstrip gasket sit in the sun and warm up, before installation. Warm weatherstrip is easier to fit than cold.
Former Vendor
joseph707 (03-11-2021)
Former Vendor
Ttt
