tyre wear
tyre wear
I drive a 1989 C4 and the last back tyres that i bought were khumos and within 5000 miles , they were bald . They are standard size . Just bought some new ones called falken . Those are the only choices of tyres anyhow . Just wondering what the average milage on back tyres should be really ? cheers
khumos when new
khumos when new
khumos when new
khumos when new
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
Are you just having issues with the rear? What air pressure are you running? Are the tires wearing even or do the centers wear first?
tyre wear
i was running 50 pound psi , and they wore in the centre the most . suspension is not worn , and had a wheel alignment done . Funny thing is that after the wheel alignment , the drivers door was rubbing against , fender and hood , so i filed it down until it cleared . And thanks for asking , cheers
the falken tyres
the falken tyres
To much air pressure and not evan touching body grinding
There is a new guy named hive looking for parts and info in A.U in tech right now maybe you could help him have a great day
St. Jude Donor '16
Check the sticker on the drivers door for the proper PSI, you should be running 30-35 max.
St. Jude Donor '16
Its what the manufacture recommends for the tire size and vehicle, does not matter what brand tire. I would think 30-35psi would work just fine with any 84-96 Corvette. OP stated he was running 50psi way to high.
ive always been told that the maximum is too much and the minimum is what is printed on the door sticker. I haven't gotten a consistent answer for what is actually the best inflation pressure.
