Do you know what this is???
Old 12-25-2014, 11:45 AM
John A. Marker
John A. Marker's Avatar
Default Do you know what this is???
Ford people would not understand....
I received the T-shirt for Christmas....can you figure it out...
Old 12-25-2014, 11:57 AM
Mose1
Mose1's Avatar
Default what is it ?
It's the firing order of the SBC 350
Old 12-25-2014, 12:05 PM
John A. Marker
Mose1...your very good and CORRECT!
Old 12-25-2014, 12:10 PM
ghoastrider1
ghoastrider1's Avatar
its the speed of Santa Clause , per second/miles, he travels. merry xmas
Old 12-25-2014, 12:39 PM
c4cruiser
c4cruiser's Avatar
Firing order of all the Gen 1 small-blocks from the 265 cid engine that appeared in 1955 thru the end of that engine family. Big-blocks had the same firing order too.
Old 12-25-2014, 02:29 PM
aDigitalPhantom
aDigitalPhantom's Avatar
gen 1, 2, and bbc firing order.
I wonder if rice burners think the 1324 on my license plate is the firing order...
Now how about 18726543?
Old 12-25-2014, 03:07 PM
WW7
WW7's Avatar
Prepare to get asked many many times what it means , because 99% of the people won't have a clue....I would of been one of them......WW
Old 12-25-2014, 03:20 PM
c4cruiser
c4cruiser's Avatar
LSx series motors.
Old 12-25-2014, 03:45 PM
Hot Rod Roy
Hot Rod Roy's Avatar
Okay John, when are you going to send Mose his new shirt?
Merry Christmas!
Old 12-27-2014, 07:25 PM
1lndonr
1lndonr's Avatar
I must be losing my memory but it seems like after adjusting the points thru the door on the distributor and staring at the firing order on the intake manifold so many times 45 plus years ago, wasn't it 18236574?
Old 12-27-2014, 07:36 PM
LannyL81
LannyL81's Avatar
Did not even finish reading all the numbers before I knew what they were in reference to.
Gave me a smile for the day.
Take care there John.
Old 12-27-2014, 08:47 PM
aDigitalPhantom
Yup you lost your mind.
Old 12-28-2014, 10:59 AM
Midnight 85
Midnight 85's Avatar
Finalist 2020 C4 of the Year - Modified
That is probably the first thing I memorized when I got my first Chevy. Of course there is a variation used by cam manufacturers that claim more horses can be had by using a cam with 18736542. 4 & 7 are swapped. I have never tried one of those cams.
Old 12-28-2014, 11:37 AM
QCVette
QCVette's Avatar
Me too. It is a sequence I can't seem to forget since I used it so many times.
I can remember that, but I can never seem to remember the LS firing order for the C5's or later. (18726543 I had to look it up.)
Nice shirt.
Old 12-28-2014, 12:31 PM
aDigitalPhantom
Here is something useless I wish I could forget IDDQD, but I cant seem to forget it.
I found a site that has a shirt that looks the same, but they want 10 reserved before they will sell any.
Old 12-28-2014, 08:35 PM
kkperformance
kkperformance's Avatar
sweet- its also the fireing order of most small block mopars- they had to copy GM of course.lol
Old 12-28-2014, 11:40 PM
Klondike
Klondike's Avatar
If you look at the order of firing on the block instead of the different numbering systems , and start with number eight cylinder on the Chevy instead of #One, the order of firing follows the same pattern of order as a small block Ford 260-302. So if your a Ford guy and don't know the firing order of a Chevy, just pretend it's a Ford and the firing order still works. Later when they came out with the 351W they changed the firing order to keep cylinders 1 and 5 from firing in sequence so as to take the torque load off the front main bearing. Learned that from a Ford engineer when I worked at Automotive Research years ago.
To Do you know what this is???
Quick Reply: Do you know what this is???
