help newbie. new battery and now radio doesnt work
Al
I disconnect the battery all the time on my 1996 LT4 when I am not going to be driving it for a week or more, never has affected the radio since 1996 except for the loss of the pre-set radio stations.
Nice car!!!
I highly respect your input on this forum, thank you.
I've been a maintenance electrician/mechanic all my life. You always look for the obvious and easiest first, as that will usually resolve the problem.
We parked the wife's '92 in a storage area abouts 10 miles away last year, as it was "secure" and relatively cheap. No outlets to connect a tender, so I disconnected the battery. When we brought her out this spring, it exhibited the exact same issue the OP described. I mean't no disrespect to the OP, just trying to help a fellow C4 owner...
Paul,
I wuz in agreement w/ you! "Occam's Razor"
Never heard of Occam's Razor before, but checked out the link...
Al
ok I just realized the antenna isn't going up. and the buzzing sound from radio.... might be amps not turning on??
fuses look ok
everything seems to work on the radio. just buzzing sound and antenna not going up. sound doesn't go up and down as you turn volume ****.
what speakers have built in amp and what ones don't. if I cant figure it out I will replace the radio. but would rather keep stock....
fuses look ok
fuses look ok
fuses look ok
