Bose CDM
I would think so. Do you have the number from the label on the CDM? Most light CK trucks '88 - maybe '94 used a CDM with only a control box visible at the dash. I've never had the need to check but I'd think these would work for anything that isn't Bose. Any of the other GM's that use a CDM also should work. There were a few.
I don't have the number and since I just had surgery, I won't be climbing around to find it for a while.
I was suspecting that others would interchange, but not sure which ones.
