Hatch Stays Closed
Old 08-20-2014, 07:23 PM
C4ProjectCar
C4ProjectCar's Avatar
Default Hatch Stays Closed
When I press the hatch open button, I hear it unlatch but it doesn't automatically raise. I can hold the button and push it open, but it pulls closed. It's like the shocks on it magically reversed - they want to pull it closed instead of push it open. It was working just fine, but now it does this. I'm hoping there's a simple answer out there.
Old 08-20-2014, 07:42 PM
c4cruiser
c4cruiser's Avatar
Sounds like both of the struts are shot. The glass hatch is pretty heavy and if the gas pressure in the struts is too low, it will seem like they are trying to close it.
I would suggest replacing the two struts.
Old 08-20-2014, 08:12 PM
C4ProjectCar
The previous owner said he just had both of them replaced. How could two new struts simultaneously go out?
EDIT: Correction. I think he just had one replaced.
Old 08-20-2014, 08:17 PM
HlhnEast
HlhnEast's Avatar
The glass may also be stuck to the gasket. Try and see if you can raise it by grabbing with your fingers and oulling up. Mine gets stuck sometimes and I sprinkle a bit of talcum/baby powder on the gaskets. If the glass comes right up with your fingers, the struts are bad as Cruiser suggests.
Old 08-20-2014, 08:19 PM
C4ProjectCar
I can get it open, it just doesn't stay open.
Old 08-20-2014, 11:27 PM
C4ProjectCar
After looking at it some more, I'm leaning toward one of the struts being bad... like you said. Thanks.
Old 08-21-2014, 10:43 AM
JrRifleCoach
JrRifleCoach's Avatar
Location: Freedom is never more than one generation away from extinction.
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21-'22-'23-'24
Chances are BOTH struts are gone.
Old 08-21-2014, 02:21 PM
C4ProjectCar
Well, guess I'll just have to take them off and see.
Old 08-21-2014, 02:25 PM
WW7
WW7's Avatar
Here they are on "Corvette Central" shop around for the best price.......WW
http://www.parts123.com/parts123/yb....5Z50000050F~~~
Old 08-21-2014, 02:27 PM
C4ProjectCar
Thanks.
Old 08-21-2014, 02:29 PM
WW7
WW7's Avatar
Ebay seems to have the best price around..Plus Free shipping.......WW
http://www.ebay.com/itm/2-Corvette-1984-to-1996-Rear-Hatch-Window-Lift-Supports-Struts-Strong-Arm-/231098989304?pt=Motors_Car_Truck_Parts_Accessories&fits=Model%3ACorvette&hash=item35ce92baf8&vxp=mtr#ht_5448wt_1610
Old 08-21-2014, 02:31 PM
C4ProjectCar
2 Corvette 1984 to 1996 Rear Hatch Window Lift Supports Struts Strong Arm | eBay
Wow, $44 with free shipping for both is a steal. Thanks!
Old 08-21-2014, 07:51 PM
JrRifleCoach
That glass hatch is heavy!
Support it with something to hold the weight when replacing the struts!
Otherwise, plan on having a secondary problem like a wrenched back or something worse.
Old 08-21-2014, 08:03 PM
C4ProjectCar
Thanks for the tip.
To Hatch Stays Closed
Quick Reply: Hatch Stays Closed
