Emissions
Old 08-14-2014, 01:59 PM
sriser
sriser's Avatar
Default Emissions
Failed emissions test #1:
High HC (barely out of spec)
Figured since the car was driven about 1000 miles per year and when i got it a few days ago there were cobwebs around the filler cap, I suspected simply that it just needed to be driven with some fresh fuel. Did that. And changed the 02 sensor. Checked timing 6 deg BTDC in Drive.
Failed emissions test #2:
HC was fine, now it was way out of spec on NOx. Crazy.
My thought is to replace the EGR despite it seeming to funciton properly when I tested it. Also changing spark plugs, cap, rotor, AIR pump check valves, air filter, and fuel filter to be changed before next test. My thought is that it is suffering from lean misfire raising cylinder temps causing the high NOx. Could be a clogged fuel filter. Fuel injectors are relativley new and all had 17ohms resistance.
So, anybody have a L98 with high NOx that eventually passed and what did you do?
Old 08-14-2014, 03:46 PM
tbirdsps
tbirdsps's Avatar
I haven't have a problem but you are right on the money thinking there's a lean issue. That will cause high NOX.
Old 08-14-2014, 07:38 PM
kimmer
kimmer's Avatar
C4 of the Year Finalist
Acetone in the tank does wonders.
Old 08-14-2014, 09:13 PM
bogus
bogus's Avatar
If the EGR valve was bad, you would know it.
Get a bottle of "Smog chek" from your local parts pimp. That should take care of it.
If not, you are more then likely in need of a new catalytic converter.
Old 08-18-2014, 09:14 AM
sriser
sriser's Avatar
Doing that too. IF it doesn't sqeak past this time, I am going to change out the cats.
Old 08-18-2014, 09:20 AM
GKK
GKK's Avatar
Is the exhaust system stock?...
Headers or larger diameter exhaust pipes will reduce the back pressure needed for the EGR valve to operate correctly.
Old 08-18-2014, 12:54 PM
mike100
mike100's Avatar
Did you actually have to change the ign timing or did you just check it? If you accidentally set too much advance, the NOx will be elevated.
Old 08-22-2014, 09:12 AM
sriser
sriser's Avatar
Passed with huge margin to spare. Spent a grand total of $16. Changed out the AIR check valves on both exhaust banks.
Both were so corroded that they had perhaps 10% air flow. Boom. Done.
Old 08-22-2014, 12:49 PM
bogus
bogus's Avatar
good catch!
Old 08-22-2014, 02:39 PM
PLRX
PLRX's Avatar
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
I didnt know the do "The Sniffer" in Virginia. The virus is spreading from California into all other states.
This is no good, we need a gearhead POTUS.
To Emissions
Quick Reply: Emissions
