C4 Bling!!
Ohhhh, shiny,, I was looking at Melrose when I was shopping for headers, those and TPIS were the top "2" I was interested in...So how did I end up with "Hookers"???.. ..Those should add some shine under the hood.......WW
Maybe you just like Hookers? I think there are supports groups for that.
You're going to love the fit of those headers. I put Melrose on mine with the new engine this past winter and they are not only the best looking headers I have seen but the fit is second to none. I bought the entire system and it all fit where it is supposed to and it was just a matter of slipping it together and putting on the clamps. Great choice!
Too bad it wont work with my C5 batwing pan.
Cutouts
Aftermarket makes electronic cut outs, or you can have the exhaust come out before your rear tire wit a 3 bolt flange with a cover you can remove so you are running straight pipes, just unscrew 3 bolts on each side and this is before the muffler and you bypass the mufflers and gain HP for sure, just an idea, but I have seen it and heard it,AWESOME!!
