85 Z51 Steering Problems
Old 08-05-2014, 07:43 PM
J W Drew
J W Drew's Avatar
Default 85 Z51 Steering Problems
Hey Guys. Started a thread a few months ago about my steering float problem. Listened to all your recommendations and followed your instructions.
Some specifics: New Tires and Shocks, ball joints and tie rod ends good. No play in the steering. Had a 4 way done and increased the caster to 5.1 degrees and toe in to .01.
I still have to compensate constantly to the left and right while traveling on the Freeway. Not a pleasure to drive.
Any other suggestions?
Thanks,
JW
Old 08-05-2014, 08:14 PM
Williamlindsey
Williamlindsey's Avatar
Default sway
Thanks,
JW
have you checked the gearbox? could be some slop in the gearbox.
Old 08-05-2014, 08:20 PM
J W Drew
J W Drew's Avatar
While on the lift, we have moved the wheels left to right and found no slop. Accordingly, I would think that would exclude the gear box as the problem.
Thanks for your response.
JW
Old 08-05-2014, 08:36 PM
WVZR-1
WVZR-1's Avatar
Received 2,262 Likes on 2,025 Posts
I would say you've overlooked something then if the car wanders/floats as badly as you mention. An intermediate shaft in an early car I would think would be the first suspect but there is something that you've not caught yet for sure. Is the person checking it with you an experience alignment technician? If it's just you and a friend with no experience I'd get the fellow that aligned it to drive it. If he's qualified he should be able to find it.
Old 08-05-2014, 09:00 PM
TBSS/85vette
TBSS/85vette's Avatar
My 1985 does the same. New tires, shocks, ball joints and tie rods good. I figured after 30 years the steering rack has had it and going to send it in to be rebuilt in the fall. Catch a rut in the pavement and the car just goes with it.
Old 08-05-2014, 10:29 PM
J W Drew
J W Drew's Avatar
You could be right TBSS. I was thinking the same, but hate to throw parts at it. To WVZR-1, The company I used is a well known and respected alignment shop.
Thanks for the interest,
JW
Old 08-05-2014, 10:54 PM
JrRifleCoach
JrRifleCoach's Avatar
Location: Freedom is never more than one generation away from extinction.
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21-'22-'23-'24
Wide tires will cause the front to hunt or steer when the surface is lightly rutted.
Just curious, what are the rear alignment settings?
Old 08-05-2014, 11:15 PM
J W Drew
J W Drew's Avatar
Left camber is 0.0 degrees and toe is .03 degrees. Right camber is 0.1 and toe is .03.
JW
Old 08-06-2014, 04:30 AM
Cliff Harris
Cliff Harris's Avatar
Check the rear toe rods at the center. If they're loose then your rear end is steering the car. The test is to unbolt the outer ends and then wiggle them around. They should not droop and they should be tight in the inner sockets.
Old 08-06-2014, 06:46 AM
WVZR-1
WVZR-1's Avatar
JW
I would have thought that the shop then would have checked the rear toe link that Cliff mentions but it's certainly possible it was overlooked.
You mention only "freeways". Is it only a specific stretch of highway or "ALL"?
Have the mounts failed? How was the intermediate shaft checked?
Old 08-06-2014, 07:17 AM
blackozvet
blackozvet's Avatar
Describe the age and condition of the tyres ?
check the manufacture date on the sidewall.
look closely for any 'Feathering' or uneven tread wear.
Old 08-06-2014, 07:50 AM
WVZR-1
WVZR-1's Avatar
OP mentioned tires/tyres are new as well as shocks.
Old 08-06-2014, 08:02 AM
blackozvet
blackozvet's Avatar
thats why I asked about the production date, there are new tyres and "new" tyres !
Old 08-06-2014, 12:39 PM
JrRifleCoach
JW
Seems OK.
Old 08-07-2014, 12:40 PM
J W Drew
J W Drew's Avatar
Freeway only. Steers well on an arterial at 40 MPH. Tires are 2014. 255/50/16. Just bought from Tire Rack. Had the same problem with the old tires.
JW
Old 08-07-2014, 12:54 PM
GKK
GKK's Avatar
What are the condition of all the suspension bushings and ball joints?...
Old 08-07-2014, 01:36 PM
J W Drew
J W Drew's Avatar
I'm told the bushings and ball joints are all good. However, suspect all the components are original. 1985 with 88k. I am taking the car back and will provide the front end mechanic with all your comments. Should give him some things to look for.
Thanks,
JW
To 85 Z51 Steering Problems
Old 08-07-2014, 02:40 PM
JrRifleCoach
Id suggest looking at the thrust angle ensuring it is as close to zero as possible.
Also tell the alignment guy you do NOT want him to correct for the crown in the road.
Make sure your test drive is on a flat road.
Old 08-07-2014, 09:33 PM
JVH
JVH's Avatar
Steering shaft ok?
Old 08-08-2014, 12:58 AM
JrRifleCoach
If the steering and suspension linkage is tight, then check alignment.
Alignment checks good, what are the settings. Thrust angle?
My 86 would "rear steer" when feathering the throttle holding a constant speed.
Sounds similar to the op's complaint. Maybe not the same.
I replaced every last joint and rubber with new or solid.
Chased that gremlin for years and reduced it with rear toe and thrust angle.
Haven't tried any combinations to experiment with, so its better but not gone.
Setting the thrust angle as close to zero as possible with a total of .03 rear toe.
The front was set with maximum caster so both sides were equal and at the max factory limit.
Front toe total 0.2 in.
Front and rear camber 0.4 - 0.3 neg
Turns in nicely, comes out hard. Solid in the straight.
Coupled with the Kumho XS's, perfect combination for the high country twisties.
Quick Reply: 85 Z51 Steering Problems
