Better braking for your C4
Old 07-26-2014, 11:36 AM
Adam@Amp'dAutosport.com
Supporting Vendor
Adam@Amp'dAutosport.com's Avatar
St. Jude Donor '11,'13
Default Better braking for your C4
If you are looking to upgrade your brakes for street or track, Carbotech Performance Brakes has pads for your application. I will be happy to help answer your question on which compound is best for you, if you are interested.
Carbotech™ 1521™
The Carbotech™ 1521™ is our high performance street compound. The 1521™ compound is known for its release and modulation, along with unmatched rotor friendliness. 1521™ is also a very low dusting and low noise compound with an excellent initial bite. This compound's excellent linear torque production provides incredible braking force without ABS intervention. Carbotech™ 1521™ operating range starts out at ambient and goes up to 800°F (426°C+). 1521™ is suitable for ALL street cars, perfect for your tow vehicle or fleet vehicle. Carbotech™ 1521™ is NOT recommended for ANY track use.
Carbotech™ AX6™
The AX6™ is specifically engineered for Autocross applications. A high torque brake compound delivering reliable and consistent performance over a very wide operating temperature range of 50°F to 1000°F + (10°C to 537°C+). The advanced compound matrix provides an excellent initial bite, high coefficient of friction at lower temperatures along with very progressive brake modulation and release characteristics. Many drivers use the AX6™ for street driving as well, even though Carbotech™ doesn't recommend street driving with AX6™ due to possible elevated levels of dust and noise. AX6™ is NOT recommended as a race compound in most applications.
Carbotech™ XP8™
A high torque brake compound with a wide operating temperature range of 200°F-1250°F+ (93°C to 676°C+). Carbotech™ XP8™ is the first of our racing compounds. Good initial bite at race temperatures, high coefficient of friction, excellent modulation and release characteristics. Extremely high fade resistance and very rotor friendly. Perfect for track day use with any tire and can still be driven safely to and from the track. Carbotech™ does NOT recommended XP8™ as a daily driven street pad due to elevated levels of dust and noise. Carbotech™ XP8™ is a great compound on the front & rear of most open wheel and sports racers.
Carbotech™ XP10™
When Carbotech™ unleashed the XP10™ to the general public it immediately gathered multiple regional, divisional, and national championships. The XP10™ has a very strong initial bite with a coefficient of friction and rotor friendliness unmatched in the industry. Fade resistance is in excess of 1475°F (801°C). XP10™ still maintains the highly praised release, excellent modulation and rotor friendliness that have made all Carbotech™ compounds so successful. Carbotech™ XP10™ is not recommended as a daily-driven street pad due to possible elevated levels of dust and noise.
Carbotech™ XP12™
Another highly successful XP™ series compound with an excellent initial bite, torque and fade resistance over and above the XP10™ compound. XP12™ has temperature range of 250°F to 1850°F+ (121°C to 1010°C+). The XP12™ has that excellent Carbotech™ release and modulation that has made all other Carbotech™ compounds so successful. The XP12™ is more rotor aggressive than XP10™, but compared to the competition the XP12™ is still very rotor friendly. XP12™ is NOT recommended for use as a daily driven street pad due to possible elevated levels of dust and noise.
Carbotech™ XP20™
The latest iteration of the highly successful XP™ series of compounds. XP20™ is a step up from the highly successful XP16™ compound. With an extremely aggressive initial bite, linear torque curve and excellent fade resistance the XP20™ is another major step in progression of the highly successful XP™ series line of compounds from Carbotech™. XP20™ has a temperature range of 275°F to 2000°F+ (135°C to 1093°C+). Carbotech™ XP20™ maintains our tradition of having the outstanding release and modulation that has made all other Carbotech™ compounds so successful. Carbotech™ XP20™ is NOT recommended for use as a daily driven street pad due to possible elevated levels of dust and noise.
Carbotech™ XP24™
XP24™ is the pinnacle compound of the extremely successful XP™ Series of compounds engineered by Carbotech™. This compound is based on the same fundamentals that exist in all other Carbotech™ formulations. XP24™ has even more initial bite, more overall bite, and more torque along with the most linear torque curve we have ever offered. The thermal characteristics are of the highest Carbotech™ offers along with one of the highest coefficient of friction ratings offered by anyone in the braking industry. This compound is the longest wearing compound Carbotech™ offers as it was originally engineered for endurance applications at the highest pro racing levels. This revolutionary new compound has been extremely successful with open wheel, closed wheel, sprint and endurance applications. XP24™ has a temperature range of 400°F to 2000°F+ (204°C to 1093°C+). Carbotech™ XP24™ is NOT recommended for use as a daily driven street pad due to possible elevated levels of dust and noise along with the necessary heat required to work properly.
Carbotech™ RP2™
The RP2™ compound was engineered for endurance racing based on our highly successful XP™ Series formulations. RP2™ has strong initial bite, a little less modulation than our XP12™, but still maintains the rotor friendliness of our XP™ series compounds. RP2™ has great fade resistance with a temperature range of 250°F to 1450°F+ (121°C to 787°C). RP2™ is as rotor friendly as our XP™ series compounds. Carbotech™ RP2™ is NOT recommended for use as a daily driven street pad due to possible elevated levels of dust and noise.
__________________
Adam Adelstein
Amp’D Autosport.com
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: sales@ampdautosport.com
Web Site & Direct ordering http://ampdautosport.com/
All major CC and Pay Pal accepted.
Check out Promo code:z28
YellowEarl (01-26-2021)
Old 07-28-2014, 01:11 PM
Supporting Vendor
Back to work Monday
Old 08-04-2014, 11:27 AM
Supporting Vendor
Old 08-09-2014, 11:43 AM
Supporting Vendor
Open Saturday give us a call
Old 08-11-2014, 05:21 PM
Supporting Vendor
Working late Monday night give us a call
Old 08-16-2014, 08:28 AM
Supporting Vendor
Open Saturday
Old 08-16-2014, 12:33 PM
DinoBob
DinoBob's Avatar
Compare with Hawk HP?
Old 08-17-2014, 12:34 AM
Supporting Vendor
I don't know what you are doing with the car. Below are some options. More info would be great.
Carbotech™ 1521™
Carbotech™ AX6™
Carbotech™ XP8™
Carbotech™ XP10™
Old 08-19-2014, 11:54 AM
Supporting Vendor
Back to school Tuesday
Old 08-22-2014, 10:36 AM
Supporting Vendor
Friday
Old 08-26-2014, 12:09 PM
merrick
merrick's Avatar
Hello,
I am looking for a street pads with most stopping ability. I perfer stopping over the noise and dust. It looks like the AX6 would be best. How will these compare to Hawk HP? My vette has the stock 13" front rotors with tire width of 285 front / 315 rear. Do you recommend mixing compounds front and rear?
Thanks!
Old 08-26-2014, 07:59 PM
Supporting Vendor
Originally Posted by merrick
Hello,
Thanks!
Are you Auto X the car or just normal street driving?
Old 08-26-2014, 10:28 PM
merrick
merrick's Avatar
Street driving. I want the max braking with a cold pad regardless of noise and dust.
Old 08-26-2014, 10:40 PM
merrick
merrick's Avatar
From the "about us" section of Carbotech website says, "It was over eight years ago that Carbotech started building brake pads out of Ceramic, Kevlar, and Carbon for street, autocross and racing applications. Carbotech is the only brake pad manufacturer in the world with a complete line of Ceramic compounds for street, autocross, and track use. Carbotech-Ceramic™ compounds are known for their unsurpassed release & modulation, while maintaining very consistent torque control characteristics. Carbotech brake pads are extremely rotor friendly and contain contain non-corrosive brake dust, that’s something that has been unmatched by any other brake pad in the industry."
Carbon is corrosive to aluminum, so I think that is a false claim of these pads have non-corrosive dust
Old 08-27-2014, 09:30 AM
Supporting Vendor
The AX6 will work best for what you are looking for.
PapaFred (10-07-2023)
Old 08-28-2014, 02:02 PM
jaa1992
jaa1992's Avatar
Location: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps GA
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
I can confirm the "non-corrosive" part of this claim.
I've been using Carbotech pads on my 92 for as long as they have been in business. I have no additional pitting or corrosion on my A-arms, rims or anything else.
I put XP8 on all 4 corners of my Camaro over 2 years ago (it sees limited road course usage). They were just replaced because the wife hated the squeal and they finally wore out.
Wheels cleaned up nicely when I upgraded the front brakes and replaced the rear pads.
The carbotech XP pads are dusty, but they work.
Old 08-30-2014, 09:45 AM
Supporting Vendor
Open last day of the month, give us a call 216-780-8825
To Better braking for your C4
Old 09-02-2014, 12:13 PM
Supporting Vendor
New month
Old 09-04-2014, 03:29 PM
roadcaqpt
roadcaqpt's Avatar
Well boys these are some bada$$ pads installed on my 95 base that used to brake like it was on greased skids. In stalled the street pad along with new vented an drilled rotor. Adam calls the drilled rotors cheese graters!. Anyway braking is nothing but fantastic. Around town just a tap does it. From triple digits a little pressure halls her down. No noise and very little dust even after a long weekend in the mtns. Good luck.
Old 09-05-2014, 08:40 AM
Supporting Vendor
Thanks for the feed back
Quick Reply: Better braking for your C4
