Where to put jack stands on'95
Looking to do some work on my '95 and would like it on stands. Where should jack stands be positioned? Did not see anything in owners manual.....thanks
Neither response answers the OP's question, as the mentioned points are for the jack, not jackstands. If that's where you would put jackstands, where would the lifting points be?
My neighbor claims to be a former GM tech, and swears if you lift these cars from the wrong points, there's a good chance of cracking the windshield...
Any advice from the senior members would be greatly appreciated...
Al
I place the jack on the frame rail below the mirror on one side. After jacking the car up, put jack stands one the frame rail between the arrows. Do the same with the other side. I've been doing this for over 30 years and my car hasn't bent nor has the windshield cracked. In fact, my car always sits like this when it is in the garage between races.
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
Another location you can use
Rear
Front
Rear
Front
Anywhere along the frail rails is fine. You have to watch out for brake / fuel lines that can be damaged by the shoe on the jack stand.
When I worked at a GM dealership years ago, we always opened the the doors off the strikers to avoid a possible windshield crack. Even on the older C2 and C3 cars. I think it was bogus, if there was that much body flex the windshield would fail under normal driving on the street.
One video I found.. If all else fails Google is your friend..
C4 Corvette Vehicle Jack Points and Procedure by Paul Koerner - YouTube
