Roof Tool
Cruising
Roof Tool
My 1995 Coupe did not come with the roof removal tool. Any suggestions on if there is another tool I can use/or purchase one? I am also looking for a new passive key entry fob and ideas where I can get one for less than $135?
Go down to your local auto parts store and buy a torx wrench set. I bought one at Auto zone some years ago for about 6 bucks. All sizes come in a fold down holder just like a allen wrench set. The largest size in the set fits the roof bolts. I don't remember the number of the size that fits the roof but it works perfectly. That's what I use all the time rather than a 1/4 inch socket with a torx bit in the socket.
You checked inside the back of console - it has a tendency to blend in. If it is not there - IIRC it should be a T40 torx. You can get a folding set like this at Autozone or other places -
http://www.autozone.com/autozone/acc...er=914173_0_0_
Or buy the tool on Ebay -
http://www.ebay.com/itm/1984-1996-C4-Removable-Top-Removal-Ratchet-Tool-NEW-Corvette-/121356564121?pt=Motors_Car_Truck_Parts_Accessories&fits=Model%3ACorvette&hash=item1c416a3699&vxp=mtr
If you go with just using a torx socket, make sure the torx section is long enough to reach. When I tried, I found some of my torx sockets were too big a diameter to go into the hole to let the torx engage.
I finally got the OEM wrench and keep it in the console. Pretty cheap, they work, and original.
Here is an example
http://www.ecklerscorvette.com/corve...1984-2033.html
P.S. After you remove the top be prepared for a wobbly ride. The targa top is a structural part of the car. The front end is going to 'bounce' around, this is normal and not much fun to experience. Enjoy the open sky view!
I bought mine off fleabay from seller "fparts." I'm thinking these guys are also a forum member/vendor - ??? anyway, decent quality tool, no complaints.
