Help: 1995 LH Spindle Bent??
I am trying to determine if my 1995 LH front spindle is bent.
How can I determine if it is bent without removing?
Can someone give me some measurements of their spindle?
Maybe the upper tower of this spindle is bent?
The control arms are NOS but there is something screwy with my uppers.
How can I determine if I have the correct upper control arm installed on the Left side. The GM part Numbers don't jive and are obsolete, but the left does have an L and the existing right has an R. I assume the letters are correct.
Again, How can I determine if the Front LH spindle is bent?
Must it be removed?
Can someone give me some measurements of a good spindle?
Pictures of a LH upper control arm on a car and a spindle known to be good would help.
How should the LH upper control arm bushing look from the wheel side? A picture may help.
RG
Must it be removed?
RG
