Rough idle, backfires 90 vette
Hello everyone.
Please, need help with my 90 vette 172k. Just drove Miami to Ft. Lauderdale, Fl about 44 miles. On my way back car started to run rough and upon acceleration and deceleration it backfires. Checked as much as I could. Filled up with premium gas, injector cleaner, no codes, recent plugs, wires, fuel pump, rotor, cap. Injectors about two years (5k ago). Just checked timing (6 btc). Idle about 600 rpm. Can't figure out. Possible bad injector? Any suggestions .
Thank you in advance.
Rick.
Rick.
After checking resistance to injectors, I discovered that # 5 injector, the resistance is 1.8 ohms. Will replace next week, also, great time to delete emissions and EGR valve to clean up engine bay.
Leave the emissions alone, please. We car guys get a bad enough rap without someone deleting equipment that works as designed and does not rob horsepower. Your kids breathe too.
