Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 General Discussion
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
General C4 Corvette Discussion not covered in Tech
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-15-2014, 11:42 PM   #1
scotth48
CF Senior Member
Default Driveshaft u-joints-best brand and quality '93 6speed
The drive shaft will be out for my engine swap and thought I should replace the universals also. The car has 100,000 miles and not sure if they are the originals. What recommendations for them as for quality and brand/manufacture. Should they be a sealed type or get them with a grease zerk? Are any made in US or will I have to settle for china made? Any part numbers? 1993 6 speed. Thanks.
scotth48 is offline   Reply With Quote
Old 05-16-2014, 02:54 AM   #2
WVZR-1
CF Senior Member
Quote:
The decision is yours. Here's all of the information regarding the correct Spicers.
http://forums.corvetteforum.com/1586416025-post1.html
5-1310X OR 5-3613X would be the choices for the drive-shaft.
WVZR-1 is online now   Reply With Quote
Old 05-16-2014, 05:38 AM   #3
eutu1984
CF Senior Member
Support Corvetteforum!
eutu1984's Avatar
https://www.facebook.com/eugene.tuorto
If you have 100K on the u-joints you should go ahead and change the half shaft u-joints at the same time. those wear out more than the prop shaft u-joints.
eutu1984 is offline   Reply With Quote
Old 05-16-2014, 11:02 AM   #4
Skruffy
CF Member
Default Additional Universal Info
Quote:
Additional Universal Joint R&D...
1)...
http://forums.corvetteforum.com/c4-t...acement-2.html
2)....
http://tinyurl.com/ky2b5tk
3)....
Make sure you specify these washers be replaced:
http://forums.corvetteforum.com/c4-t...e-washers.html
Skruffy is offline   Reply With Quote
Old 05-16-2014, 06:48 PM   #5
hcbph
CF Senior Member
hcbph's Avatar
Default Misc
I just changed out the u-joints on the half shafts of mine this last month. The car has 78K on the odometer. The U-joints in there were Spicers and not original, they were full of rust and some of the needle bearings had virtually disintegrated.
I used Moog's non-greasable replacements and they have a lifetime warranty for what it's worth.
hcbph is offline   Reply With Quote
Old 05-16-2014, 06:55 PM   #6
rocco16
CF Senior Member
rocco16's Avatar
Location: SCMR Rat Pack'r Charter Member..Great Bend KS
Quote:
Who's life...yours or the U-joints?
rocco16 is offline   Reply With Quote
Old 05-16-2014, 07:34 PM   #7
hcbph
CF Senior Member
hcbph's Avatar
Default Warranty info
Quote:
MOOG/PRECISION Warranty Information
Universal joints limited lifetime (excluding racing, off-road, or fleet vehicles)
Old 05-17-2014, 10:48 AM   #8
scotth48
CF Senior Member
Thanks for all the info and appreciate the part numbers. So I need to go with the coated u joints 5-3613x for the drive shaft and 5-3615x for the coated half shafts. I probably should use new bolts and retainers too!
Old 05-17-2014, 11:18 AM   #9
WVZR-1
CF Senior Member
New straps and bolts aren't required. Just a good clean-up with a wire brush should do. The drive shaft to pinion flange are SAE and the half-shaft to differential and also the spindle are metric. Don't mix them and make sure if you want new you get the appropriate ones. If you want new mention that and I'll give you the information.
Old 05-17-2014, 12:34 PM   #10
scotth48
CF Senior Member
Yes WVZR1, if you have that info I would appreciate it. Thanks.
Old 05-17-2014, 12:54 PM   #11
WVZR-1
CF Senior Member
2-70-18X should get you the strap and bolts for the drive shaft. 2 straps and 4 bolts per package. 3-70-48X would do 2 straps and 4 bolts for the half-shafts, for all new you would need 4.
You can do bolts only or straps also only I believe. This is not where I buy but they're good people. You could use them for bolts, straps or packages.
Use either of the numbers that I gave you for a search option.
http://www.northerndrivetrain.com/
Old 05-17-2014, 09:28 PM   #12
Nowhere Man
CF Senior Member
Nowhere Man's Avatar
http://www.facebook.com/home.php?
Send a message via AIM to Nowhere Man
I would replace the half shaft joints before I even thought about drive shaft. But that's me
Nowhere Man is online now   Reply With Quote
Old 05-17-2014, 11:02 PM   #13
scotth48
CF Senior Member
These are the metric ones?
Are these Spicer part numbers too?
Old 05-17-2014, 11:05 PM   #14
WVZR-1
CF Senior Member
3-70-48X would do 2 straps and 4 bolts for the half-shafts, for all new you would need 4These are the metric ones?
Yes 4 of that part #
Old 05-18-2014, 07:54 AM   #15
scotth48
CF Senior Member
Found a Fleet Pride in Lansing, about 18 miles away that carry Spicer parts. Maybe a little more expensive than online. Maybe they will give me my farm discount! Will get the two drive shaft u-joints and strap kits, and four u-joints and four strap kits for the half shafts. Will ask about French lock to use instead of lock washers as mentioned in other forum posting. Replacing all this will give me peace of mind to take a longer trip once I get the engine in.
Reload this Page Driveshaft u-joints-best brand and quality '93 6speed
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
