Top 10 Mistakes Car Owners Make (Video)
Hey guys,
Thanks for all of the ideas and suggestions you guys posted up on the form for some of the top mistakes. There were a lot of good ones and I picked out what I thought were the top 10 mistakes.
Let me know what you think!
**Also, if you enjoyed the video, give it a “thumbs up” on YouTube (it helps me out, thanks)***
Received 4,505 Likes
U.S. Air Force
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
Good advice, Thanks.
I think its a mistake to check the vehicle for proper tire pressure. OEM tires may call for, for example, 32psi - and that is what is printed on the car. But what if the owner (or a prior owner) changed tires to a high efficiency tire. Those tires typically require much higher pressures (in the neighborhood of 35-36 psi). Using the car's recommended pressure will negate the benefits of the high efficiency tires. So for proper pressure, check the tire and/or the recommended tire pressure from the tire manufacturer for the specific tire on the car.
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
This is a great video for nOObs and women.
I would had been cool to hire that voice they use for sneak previews. I bet that guy smokes 10 packs a day.
Pro Mechanic
Mistake #1 is wrong.
Told you that in your other thread too.
Rest of it is good info though.
