Valve Cover Bolts
Valve Cover Bolts
Can anyone tell me that is using the Fel-Pro PermaDryPlus Valve Cover Gaskets VS12869T if the stock valve cover bolts will work or will I need longer ones?
I need to do my passenger side and decided to try the Fel-Pro instead of RTV.
If I need longer bolts could you point me in the right direction of which ones to get.
Thanks in advance.
I am using the factory covers if it matters.
Thanks in advance.
The FelPro gaskets came with valve cover hold down tabs. Do I use these?
When re-installing the valve covers do I need to put anything on the bolts? Anti-seize?
