Problem with key fob activation
6th Gear
I bought a keyless entry fob for my '95 as the car was equipped for one, but the previous owner never had one. I programmed it per manual instructions and it was working fine, then suddenly stopped. I had the same problem once before but don't remember how I fixed it. Reprogramming it did not work. (Its supposed to open the door locks and deactivate the alarm as you approach the car, and lock and set the alarm automatically when you leave the car.) Also, the buttons on the remote won't release the hatch or door lock. It's not a battery issue. Any ideas as to how to fix?
Thanks!
Thanks!
Roadster Madness. 😠
Received 1,510 Likes
St. Jude Donor '13, '20-'21
Thanks!
Thanks!
Thanks!
Thanks!
Also, could be the fob just went bad. If you could find someone else with a working C4 fob you could try programming that one to the car and verify if it is a problem with your fob. (If you can program it there is probably not a problem with the receiver).
Maybe we could help if you giver us more information. Did you check the fuses? How long did you hold down the door button. Where were you standing? Did you put an ad on Craigslist asking for soemone to let you try their fob? Did you drop the fob? How do you know it's not a battery issue? Does the PKE light come on for a couple seconds when you turn the key on?
I think you already have the answer. Replace the FOB battery. I had exactly the same problem. When I opened the trunk with the key, the alarm went off. That would only happen if the car could not detect the FOB. Replaced battery all is well.
