a/c dryer accumunlator
Does anyone know if you are suppose to have some play in the top of the a/c dryer? Mine seems to move have some give to it...is this normal?
thanks in advance
Mike
thanks in advance
Mike
No - it needs to be secure. Vibration is hard on lines and you don't want it rising up and hitting the hood. It may have the wrong one - too small for the Clamp - or the Clamp might be broken. If it has the OEM replacement installed, there will be two Schrader Valves on it (instead of one) and the Clamp has to be notched for it to fit correctly. Frankly, I don't like that unit so if I needed one, I'd just buy what NAPA has because there's only on Valve.
