1988 corvette convertible oil
Old 04-22-2014, 12:49 PM
joey.k
joey.k's Avatar
Default 1988 corvette convertible oil
hey guys. Quick question today. I own a 1988 corvette convertible and it has been running on regular oil. I was just wondering if it is ok to start using synthetic oil when I do my oil changes and if so what are the advantages and disadvantages if any???? thanks. Joey.k
Old 04-22-2014, 01:12 PM
amtronic1
amtronic1's Avatar
I also have an '88, with 200k, and I was told in no uncertain terms to not change to a synthetic now. If I had been using one like Mobil 1 from the beginning that would have been fine, but with 25 years plus on regular oil that I would have nothing but leaks to deal with now.
Old 04-22-2014, 02:23 PM
joey.k
joey.k's Avatar
thanks for the advice buddy.
Old 04-22-2014, 03:03 PM
jv9999
jv9999's Avatar
You can switch if you want. If the dino oil was changed regularly, synthetic is not going to make it suddenly start leaking. It's an old wives tale based on the assumption that synthetic will clean out the sludge that is blocking leaks now. Good dino oils have just as good detergent packages and you shouldn't have much sludge anyway.
Still reluctant? Call Mobil's tech line.
Old 04-22-2014, 03:44 PM
65Z01
65Z01's Avatar
Cruise-In II Veteran
Synthetic oil is more about being less prone to molecular breakdown than dino oils.
My prior '88 came with 96k on the clock started using Quaker State full synthetic and accumulated over 200k miles before the car was hit and totalled.
My current '88 came with 45k on the clock and using QS full syn at oil changes.
Old 04-22-2014, 04:00 PM
joey.k
joey.k's Avatar
thanks
joey.k
joey.k's Avatar
thank you.
Old 04-23-2014, 09:19 PM
DinoBob
DinoBob's Avatar
My '86 received an oil change with Mobil 1 last fall shortly after I got the car. 10/30. Shortly thereafter I began to notice the classic valve guide "puff" of smoke when starting a warm engine after sitting for a while. My next oil change, I tried Quaker State Defy conventional with added zinc. The puff has completely disappeared.
Old 04-23-2014, 09:56 PM
BstrdC4
BstrdC4's Avatar
Puff of burnt oil on start up is bad valve seals. Zinc is masking it. But doesn't fix it.
Old 04-24-2014, 12:34 AM
DinoBob
DinoBob's Avatar
More likely the conditioners in the oil than the zinc. But that's OK. It's not puffing, it uses no oil to speak of (and did not when the synthetic was in), and it runs great. Mobil 1 was not the recommended oil until years later, by the way. If the problem recurs I will address it then.
Old 04-24-2014, 02:33 AM
Cruizin
Cruizin's Avatar
There are high mileage synthetic oils designed for your application that have seal conditioners as part of their makeup.
http://www.mobiloil.com/USA-English/...age_5W-30.aspx
http://www.valvoline.com/products/br...ge-motor-oil/2
Both claim to prevent oil leaks in high mileage engines.
To 1988 corvette convertible oil
Quick Reply: 1988 corvette convertible oil
