Nitto 555 Tire Pressure?
Tire pressure
It varies, depending on the situation, but for normal street/hwy use, like da man said, check the sticker on the inside of the driver's door, just above the latch. I wanna say it is 35 psi for normal use, but check to be sure.
For drag racing, some lower their 315x35x17s to around 20-25. However, for high-speed running, air pressure is increased 5-7 psi ± depending on anticipated speed. (C-chart)
