PKE Antenna Eaten Up
UPDATED ... Yes - some mice likely ate thru some of the insulation on what I believe is the PKE wire that runs to the PKE antenna back of the coupe/inner wall. What I am looking at are 2 wires - one appears to be the seatbelt interlock and the other are 2 small wires (black/white) which seems to run from behind the driver seat to the back of the car - looks like it goes under the carpet at back of the console. The insulation on the wire, at least the small piece visible, is damaged. Is this the PKE antenna wire or something else? I think I have to pull out the carpet behind the seat, or maybe remove console to get to it. Anyone know about the PKE antenna wire?? My PKE no longer works. Thanks!
I'll look this afternoon...I currently have my dash off to replace the PKE...I suspect mouse damages as well...
I hate @#$% mice...every fall I got through 20 snaps trap with little buggers looking for a winter home!!!!
Also, having read several threads on topic, I have learned that nobody knows for sure what the NO LIGHT means in DIC. You sound like you are replacing the unit. This sounds like a horrific job. And, can you still get the receivers?
Corvettes are choice for rodents! Plastic smells good and is nice and warm.
I got a used PKE/receiver on ebay, I think it was about $50.
BTW, I took some picts of the connectors. I do see one black/white wire which attaches to what I believe is the receiver that sits above the PKE...although not a 100% of that, will check my FSM when I get home.
