How many of you have a modded C4?
#41
I say it's done because the swap is complete but the car is not done yet. Prob never will be, I want to do suspension and rear next.
#43
Mine's mostly stock
Engine:
355 ci L98 with 52MM Throttle-Body, Ported Plenum, ASM Runners, Accel siamese-ported base plate, 24# injectors, 1.6 rollers, 218 CFM CNC-ported stock heads, Corvette Challenge cheater cam, 10.6:1 compression, Canton Road-Race Oil Pan, Ron Davis Aluminum Radiator w/Integrated oil cooler, 180 Deg. Thermostat, TPIS Jet-Hot coated headers, Formato custom chip
Drivetrain:
Single-mass flywheel, CenterForce Dual-Friction clutch/pressure plate, Hurst billet shifter, Poly bushings, Mid-America lowering kit, 295/30YF18 BFG k/d's on OZ 18"x10" Monte Carlo Rims, Doug Rippie suspension modifications, Bilstein custom-valved FX3 shocks, GM DuraStop "Performance" Drilled/Slotted rotors & GS calipers
Exhaust:
3" Random Tech "bullet" cats, Corsa LT1 dual exhaust
Home Page: http://www.corvetteforum.net/c4/joe91/index.shtml
Dyno pull:
426.35 HP & 527.6 lb/ft at flywheel
Brakes and everything else came on the car...J55's, FX3 shocks custom built to Rippie specs, Rippie FX3 controller,
Car is a Z07 ordered new from GM and delivered 1/26/1991...I've owned it since new and once the warranty ran out everything short of engine machine work has been done by me.
BTW: Had it out at CotA a few weeks ago and the instructor riding with me said "I didn't think C4's could do that..."
I said "MOST can't!"
It's pretty stealthy...
Engine:
Drivetrain:
Exhaust:
Dyno pull:
#47
Unfortunately no dyno sheet yet, so i cannot say but I can say yes I modded the hell out of mine so I could be the loud, obnoxious, almost 50 year old living in my town. Which every one talks about will never grow up and is going thru their 3rd child hood and mid-life crisis, but oh yea his car is cool!
L98 - now a 383
700R4 Rebuilt and Beefed up
Factory TPI extremely ported plenum and base with 58 MM TB
36lb injectors
High Flow Fuel Pump
Ceramic Coated shorty headers
Comp Cam 08-466-8
Stainless Steel Roller Rockers 1.5
Pro-Comp 190 CC heads
Tru-Dual exhaust with Cheap Loud Mufflers
Custom Chip
Fresh Paint
After Market Stereo,
Custom Interior
L98 - now a 383
36lb injectors
High Flow Fuel Pump
Comp Cam 08-466-8
Custom Chip
Fresh Paint
Custom Interior
#50
As my log on say, I am new to corvette and definitely new to C4, is that a stock engine. That one awesome looking machine under the hood. I think I just change my mine on which model to get for next C4.
#52
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
I think randy ransome puts us all to shame!!!!
#53
Mine's mostly stock
Engine:
Drivetrain:
Exhaust:
Dyno pull:
Engine:
Drivetrain:
Exhaust:
Dyno pull:
This really goes to show that a well thought out L98 can perform.
#55
Intending to drop an LS7 in it...full cage, C6ZR1 carbon/ceramic brakes...
Got a huge job scheduled out for the next 4 months...it is certainly paying the bills, but I don't think the car will get started until fall now.
#57
Just dumped a ton of money into getting 300rwhp into my beater Civic.
That being said I haven't done too much to my car just yet. So far the list is X-Brace, Camber Brace, muffler eliminators, skip-shift delete, and splash guards. I'm currently collecting parts for a cam swap. Hoping for 370whp
#58
It was already somewhat polished when I got it but it was clear coated and it had turned Yellow over time. I just stripped the clear and did a resand and repolish. Thanks again.
I like your yellow Z.
#60
Just waiting on some time (and open space) to start on my '92 ZR1-bodied track car...
I cant believe i missed your post..more details please?
