BOSE CD Player doesn't work!
Heya! I've got an original Bose AM/FM cassette/CD player in my '93 C4. Just bought the car a few months ago. Went to play a CD and it just stuck/stopped, didn't play. Any thoughts/repairs?
I always have tried to keep the car original, but after seeing some of the systems available today it is getting harder to keep this Bose System intact. I have been tossing the idea of replacing the system with some system that will fill the 2 din completely.
This is a hard trade off. Spend a lot of money and time to keep the out dated Bose. Update the system with all the modern day features.
Still not sure...
FL Events Coordinator
St. Jude Donor'13
Personally replacing the old bose system is one of the few things you can go aftermarket with and it actually will raise the value. It is also very worth it.
Just make sure to keep the original incase you decide to sell. It is always nice to have the original because the buyer might want it.
Join the club!
Got my 94 a year ago. Had both rear amps fixed, sounded pretty good! Put in a CD and it stuck in and didn't play and stereo wouldn't work also. It finally popped out the CD a few hours later. Afraid to try the Cassette player. At least the stereo plays! Would look at aftermarket but car is "bone stock" with 24000 on odo and hate to change anything.
Have some good cassettes from org owner, do cassettes get "sucked in" like CD's? Can you pull them out if they do not play, unlike CD's?
St. Jude Donor'13
Is the CD disc stuck in the player or just will not play?
I sent the unit out of my '95 in for repair/tune-up/cleaning to the guy that most C4 owners use....now if I could just think of his name....?????
Anyways not cheap, but less than a new unit, plug new speakers, wiring, installation time.
got my 92 three years ago...replaced amps and had Dr Don fix Bose radio...wanted to keep original......sorry now...plan new double din in future....and Yes cassettes get stuck and difficult to remove with tape intact...
Bose amps
Neither one of my rear speakers played at all and 99% of the time it is the amps. Removed both rear enclosures, unpluged amp board and sent to Longwood FL to rebuild. $80 for each amp.
The parts needed are below : Price $ 38.
Reference PANASONIC YESFD13002/e13002/13002 tête laser.
http://fr.aliexpress.com/wholesale?S...D13002&catId=0
But a long job to do. Consider 3h to replace the laser pickup.
Bose amplifier repair
My Bose amplifier produce a hissing sound.
I was told that only 2 condensators have to be replace. But which ones ??
Does anyone have infos ?? Diagram, photos ??
Sincerely
Sincerely
Worked fine, even the scan function. Debbie did sound a little bit high pitched, like the playback was a little fast. What happens with a lot of old cassettes is that the little felt "tab" in the center of the open part below the tapes can come loose. You don't want debris like that in the deck.
I do have some intermittent sound issues like alternator whine, but I can live with that for now. Since I listen to a lot of streaming music, I've been using a little FM transmitter plugged into my phone. Not the best sound, and I get intermod from adjacent frequencies sometimes. I think a cassette adapter is in my near future.
Cassette stuck
Of course you have to dissasemble the radio unit. It's long but easy.
