Water Under 1995 Vette?
This is my second spring owning my 1995 Torch Red Automatic. It has just turned 27,000 and I LOVE THIS CAR.
2 Questions:
1)Last year, when it was humid outside and I was running the Air Conditioning, I would notice substantial water in the footwells on the passenger side. Anyone else have this issue?
2) Yesterday, I drove my vette and when I parked it, it was dripping water just under the passenger side onto my garage floor. It was water, it did seem to be any other fluid.
Thoughts?????
2 Questions:
Thoughts?????
2 Questions:
Thoughts?????
2 Questions:
Thoughts?????
2) Check all of the drain tubes for blockages, especially the one for the cowl vent box on the passenger's side. Was the A/C running while you were driving?
Live well,
SJW
If you get under the car and look up at the bottom of the evaporator housing you should see a hole about 1/2" in diameter. If that hole is blocked the condensation from the evaporator will go inside the car.
Thanks for the help. I am new at working on my corvette, but I am excited to do so. I have opened the hood to get at the drain tubes. Is this something I get at from up top or do I need to get under the car. Most of my cars I can get underneath- not happening on this car.
