steering column
92 coupe
recently repaired loose steering column...long term loose column due to broken bracket ignored by PO, caused abnormal wear on other parts
3 steps...two hard, one painful
1. find willing AND capable/experienced mechanic
2. find rebuilt steering column or pay for rebuild
3. Pay...Ouch!!!
feels safer 'tho...priceless
3. Pay...Ouch!!!
Just rebuilt the column in my 92 a few weeks ago. I also used www.SteeringColumnServices.com for my parts. They offer new and reconditioned tilt housings and parts. If I remember correctly if you remove it from the car and ship it to him he can rebuild for you. I used one of his reconditioned tilt housing units and was happy with the results, just like new. As far as what it takes to do it, just take your time and a few special tools. (Steering lock plate, and tilt pin remover) Just follow the factory service manual and when you take it apart lay it out on the work bench in the order it comes off. Good luck
You could also try using an oversize pin to tighten up the tilt mechanism if that is your problem. It is a relatively easy and quick repair method but the pin costs $50.00.
Here is the site -
http://www.zr1specialist.com/HAT%20W...lumn%20pin.htm
Here is the site -
