Hood Scoop,c4
7th Gear
Hood Scoop,c4
Hi all, recently I have been looking at the threads to see what people have done about hood scoops and the reasons why.
After checking things out I went ahead and added my hood scoop. I used a 40" Camaro SS scoop that I think really fits with the car, I also did not want to emulate the C6 grand sport.. I wanted a look that's slightly muscle car and yet pleasing to the eye that actually works as well. I have posted the Photos in my album. Corvette Specialty of San Diego did the work , along with quality and care the project was done at a very reasonable price. I posted the photos because I was interested on how this is done, people don't really talk about it in the forums, they just show finished product.
I had adjustments made to the car, replaced two amps, installed speakers bought on EBay, and the scoop for $1300.00. and it was done with care and I wasn't upsold on anything.
pictures please
could i get a picture of your scoop install thanks, gary g_jorgensen@msn.com<div style="margin:1rem; margin-top:...</div>
</div>
Gerard, I'm getting the Callaways for my '96 vert. Nice thing about them is that they look like they could have been factory, not stuck on. Now I'm NOT knocking Dbenci's scoop. I like it b/c it reminds me of the mid-year hoods. I'd like to see his car in white with a black stripe.....Just my opinion......I like black & white.
7th Gear
hi all ,
in time I plan on having the car repainted polo green, right now the primer black is ok until I truly figure out what I want.it's truly is a work in progress, I am the third owner and the only one that has taken a real interest other than just driving it.The rehab is about 30 percent done and once its ready some street cross fun is in its future.... after the LT4 upgrade that I am planning, the complete kit from Edelbrock with new cam as well, published 400 hp. is what they say on web site. I want it to be a daily driver as well and I think that's a nice number.
During a heater core replacement that I did my self, (next time to the shop with it)I had some dash work done as well with the help of Jodi at Vettaid. and yes there is a module for cruse control, on the way.
I am happy to report that the scoop is doing what I had hoped for the operational temp is staying between 150 and 180. and I am getting no codes, I let the car warm up to 180 so the cpu comes to life and car runs at its best. as far as wet weather I have my z71 and a few ideas bouncing around in my brain at the moment.
hi all ,
Debenci, I thought the primer stripe was permanent, that's why I commented on black & white.
What gets wet under the hood if you're caught in the rain? I was hesitating to make my scoops functional for fear of getting the wrong stuff wet.
Any idea of how much one of those replacement panels might cost?
Love you replacement dashboard ... very nice!!! Your post will be very much appreciated by those (like me) who have a later model C4 and are looking for something to replace the dreaded digital speedo. I checked out your vendor (Vettaid) and found that they now have replacement gauge panels for later C4's (1990-1996). God really does love Corvettes. Thank You!!!
do NOT attempt to 'bond' a scoop onto the SMC oem hood as it will crack/split after a short while
7th Gear
Hi all
One of my biggest concerns was water getting into places you don't want it to. That is a big reason as to why the rehab started in the first place. All the weather seals on this car were cracked and worn out . the only original ones left are the wheel well / inner door seals.
They were replaced by Corvette Specialties, I did them in two parts, I think total cost was less than 400 bucks and Dave uses ones that fit real good. It was cheaper to just have Dave do it all than buy the kit and then have his guys do it.
So my resolve is to install a Aluminum door to the inside of the intake, kinda what you would see on a Mig-29 when it taxies. as it starts to rain real good I will hit a switch. I think it will be mounted on my dash or possibly a repurposed one on the now useless info center cluster. I will employ a RC servo to actuate the door and since its low volt and they are pretty water/dust tight as well I will pull power from the under hood lights.
I had the inlet placed in the location that it is because I did not want to expose the opti spark and generator to direct inflow. I wanted to avoid cavitation /disrupted air flow or the creation of a high pressure point in on or under hood.The whole idea was (is) to dump cool air down around the back of engine compartment so it would reduce the operating/running heat exchange with the cabin.
the one component that is exposed is the oil psi sensor, this is a simple potential switch that has no digital or motorized components. My thoughts were that under normal conditions the motor can get pretty wet just by ground effect as well as 99% of the fittings are water tight and they can and do survive direct contact with water.
I think that I am pretty lucky being in SoCal, and that I am not trying to turn the car into a Sub...yet.
I will just have to keep up the maintenance as far as keeping things clean, periodic steam cleaning along with simple green "purple" will help as far as grime build up. I was thinking of a possible filter but I don't know...I am open to ideas because that's how we all learn reading the forums has helped me a lot.
I got the scoop searching E-bay and online, once I found the one I liked it cost about $80 bucks with shipping. they are in Florida I believe.
7th Gear
I have seen a 2010 zo6 that had a inlet dump just past the throttle body and he never has had any problems.. so I believe its really how bad is the water flow. garden hose or spray etc.
7th Gear
I sent an email to Vettaid to which Jody responded saying they can make a replacement dashboard for any C4 using pretty much any of the gauges available from Autometer ... and the Autometer website has some VERY nice gauges both analog and digital. My only concern is whether I'll be able to perform the installation.
Redrose, do they really spray water to check for electrical problems? Hard to believe! Anyway, I don't like the look of "stick on" stuff. It has to look like it could have been OEM or it won't get done at all. No bonding for me either. I don't want some half a$$ looking job. If it's determined that the job is beyond me then a pro shop will do it.
Dbenci, I'm in Texas which isn't really known for its rain either, but good point about ground effect water on the engine. Will an r/c servo work on 12v? Usually they operate in the 4v - 6v range.
The "God" plate reminded me that the C-7 doesn't really have a good place to mount a front plate if you're required to have one, or are and don't .
Gauges
I really like that gauge setup, not too much of a fan of the digital type display in the C4's. Grew up with gauges and still like them.
I'm not much of a scoop fan (other than maybe the old Hemi Cuda's) so really can't say much on that other than if you like it, that's all that counts.
