Sys light ?
Sys light ?
My 94 is running ok with no other problems. My SYS keeps flashing. Is this a easy fix. is there something i can eather remove,plug or replace?
sys light c4
I found on 96 and 93 the connection just aft of the battery, (Positive RED connector) on removal of bolt at the connection and you just may find light power ,clean off and your problem is over... The battery vents gasses, bingo problems
after market radio causing prob..
