Looking for some help for a non corvette
2008 focus on going issue. Turn the key dash lights come on but car wont turn over. Engine makes no sound just dead silence, I mess with it a few times could take 2 could take 5-6x eventually the car starts today the car won't start.
I don't think it's the starter usually when from my experience when they stop working they die slowly and the cranking times start to take longer. This car never did that it either started or it didn't. Any one have any insight possible ignition issue?
Im asking here cause the focus forums are terrible. This is my brothers car. He took my Corvette to work w/o asking since he claimed it was an "emergency" today. Risk I run for leaving at my moms due to her having a garage and me not. He won't be pulling this crap again he can borrow my crashed mustang that I drive 1100 miles a year to my hockey/softball games and the train station.
http://forums.corvetteforum.com/other-cars-24/
You might have better luck there.
.... Turn the key dash lights come on but car wont turn over. Engine makes no sound just dead silence, I mess with it a few times could take 2 could take 5-6x eventually the car starts today the car won't start.
Just thinking to start by checking with Ford for any recalls or simple TSB's. They have a history of problems on several models with similar symptoms... could be an ignition interlock problem.
I had a symptom like that on my '86 Corvette. I drove to the auto parts store and when I came out the dash lights would light but when I tried to crank it they went out and nothing happened. Same with a jump.
It turned out to be a bad battery cable. The side terminal battery had leaked acid and it ate up the copper wire inside the cable.
Check the battery cables for tightness (both cables, both ends).
This could be a problem with the PATS (Fords' version of VATS/Passkey security). If so, one reported workaround is to get out, close and lock the doors with your remote, then open the door with the key. This is (reportedly) supposed to reset the securilock circuit in the ECM. Another suggested work around would be to try the spare key (the one you're using may be damaged). The other usual suspects already mentioned, battery, battery cable to starter, starter solenoid, ignition switch, gear selector in park or neutral, nss, fuses, relays, etc.
To the person that said Vats. The connection by the battery is painted, causing a a bad contact. I sanded it to bare metal and the flashing security light went away.
