leaking freeze plugs
Old 12-15-2013, 03:41 PM
tntwolt
tntwolt's Avatar
Default leaking freeze plugs
anybody know if stop leak will work on freeze plugs? got one in front, don`t have the energy or funds to get it fixed.
Old 12-15-2013, 04:13 PM
Just BOB
Just BOB's Avatar
I wouldn't count on it. If one plug is leaking the rest are probably in bad shape also.
Old 12-15-2013, 05:40 PM
c4cruiser
c4cruiser's Avatar
Depending on the amount of coolant leaking, stop leak may work for a very short time. But the freeze plug leaks are usually caused by rust so don't expect a long term fix. Stop leak doesn't cure rust or even stop it.
Also, the problem with stop leak is that it winds up circulating through the entire cooling system and it may eventually cause restrictions in coolant flow.
At least if the problem you are having is with one of the two front plugs, count your blessings. Sometimes the plugs at the back of the block can leak. That will mean a trans removal along with clutch/flywheel or torque converter/flexplate.
Old 12-15-2013, 05:53 PM
hooked073
hooked073's Avatar
I would not count on it
Old 12-15-2013, 08:23 PM
tntwolt
tntwolt's Avatar
okay, its an `87. you would think they would use something that will last?.how much more would it be for a stainless or whatever plug?
Old 12-15-2013, 08:30 PM
ch@0s
ch@0s's Avatar
It lasted 27 years.
Old 12-16-2013, 05:47 AM
HlhnEast
HlhnEast's Avatar
I put Stop Leak in my '85 to fix a leaking freeze plug. Its still holding after 7 years and a complete flush of coolant. Now I have said that it will start leaking! Just remember the Stop Leak will fill your cooling system full of glop, possibly even the radiator tubes and sensor ports. Its definitely a last ditch fix. My leak was on the right forward almost inaccessible one. I will pretty much have to pull the engine to change it out so it will wait (hopefully) until I rebuild the engine next year.
Good Luck!
Old 12-16-2013, 10:49 AM
Greg Gore
Greg Gore's Avatar
Maintaining your cooling system will prevent rust. One of the key items when looking at a used car for sale is to remove the radiator cap to check for a rusty cooling system.
Old 12-16-2013, 12:13 PM
desertmike1
desertmike1's Avatar
I would try this stuff, it won't plug up your cooling system, and may buy you some time.. [The dry stuff in a tube]
http://www.goldeagle.com/products/product9D29.aspx
Old 12-16-2013, 12:38 PM
ch@0s
ch@0s's Avatar
I would not chance blowing your motor, remove the freeze plugs and replace them.
Old 12-16-2013, 12:42 PM
Greg Gore
Greg Gore's Avatar
Which also means pulling the engine to do the two in back. Probably not what the OP wanted to hear but then maintaining a 27 year old car is probably not for everyone
Old 12-16-2013, 05:06 PM
HlhnEast
HlhnEast's Avatar
Where's the big barrel of elbow grease?
Old 12-16-2013, 06:24 PM
hooked073
hooked073's Avatar
replace the ones you can get to for now. We wonder why our cars get such a bad name. people rigging things instead of fixing them right
Old 12-16-2013, 06:52 PM
tntwolt
tntwolt's Avatar
it kinda dried out at 67 yers
Old 12-16-2013, 08:00 PM
QCVette
QCVette's Avatar
I have had good luck with this also. It is a dry aluminum flake powder. I have seen it marketed by under a number of brands.
Most other stop leak products are a thick goop that clogs everything. I even had one clog the radiator so bad the car was overheating and I had to replace the radiator. I will never use that type again.
Even if you use the aluminum flake powder and it works, it may be a short term fix. You still may have to fix it right at some point.
Good luck.
Old 12-19-2013, 01:22 PM
crimsondave
4th Gear
crimsondave's Avatar
It will probably work long enough for you to get some money to fix it right. I've seen it last weeks to years and, sometimes, not at all. It's worth a shot if your strapped for cash.
To leaking freeze plugs
Quick Reply: leaking freeze plugs
