Garage lift question
Old 11-11-2013, 04:53 PM
glava2876
glava2876's Avatar
Default Garage lift question
I'm pretty sure that I will be able to pull the trigger on a direct lift four post car lift for my garage this spring.
These things seem fairly inexpensive at about $2,100.00, plus shipping and only require 110volt power.
I have an 11' ceiling, but the garage door track is lower and would make it tight to store a car on top.
Any one know if the garage door track can be extended higher and the opener moved up to get more clearance?
Old 11-11-2013, 04:58 PM
Vette Daddy
Vette Daddy's Avatar
Yep, just contact your local garage door company. I did one of mine a couple of months ago. Works like a charm.
Old 11-11-2013, 05:03 PM
glava2876
glava2876's Avatar
Originally Posted by Vette Daddy
Yep, just contact your local garage door company. I did one of minie a couple of months ago. Works like a charm.
Cool, I just called a local company and they are stopping over Friday to get a look and give me an estimate.
Knowing that we may not have everything the same, I just wondered what the cost was for you just so I have a general idea?
thanks
WW7
WW7's Avatar
Im interested to hear the response to this question myself since Im getting a 4 post lift in the spring also.. I have a 13' ceiling in my 2 car garage and either need the door track raised like your talking about, or I may have to get a roll up type door....WW
Old 11-11-2013, 05:05 PM
nutz4c4
nutz4c4's Avatar
..You will need to move the shaft line up accordingly and you will need longer cables. Not hard for a competent door technician
Old 11-11-2013, 05:39 PM
Vette Daddy
Cost was around $300. I have a coil spring. They also put spring loaded bumper stops on each rail. I'm buying a Liftmaster side mount opener for the next one, since we use that door to enter the home almost entirely.
Old 11-11-2013, 06:03 PM
85corvettec4
85corvettec4's Avatar
id give a little extra as some people use plates in between the lift and the floor
Old 11-11-2013, 07:26 PM
PLRX
PLRX's Avatar
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
Old 11-11-2013, 07:34 PM
cohocarl
cohocarl's Avatar
And worth every penny... A few years ago I purchased a BendPak HD-9. You will love it. It is SO much easier to work on most anything on the car. One warning though....you will find friends you never knew you had.
I also made a couple ramps & boxes to drive my 60" Bad Boy mower on it from the side, then raise it up to scrape off the deck.
Just used mine again last week to change the oil & filter on my quad before winter sets in. (rode it on just like the mower)
Old 11-11-2013, 07:49 PM
PLRX
PLRX's Avatar
2017 C4 of Year
True statement right there. One neighbour tried, and I told him that I charge $80/hour.
Old 11-12-2013, 01:22 PM
h.d.fire
Support Corvetteforum!
h.d.fire's Avatar
Default 4-post lift
LOL! I never thought of using that line!
Here's mine. 9' 6" ceiling height and I can still get my '86 Fiero DGP widebody underneath it. Best investment I ever made.
Old 11-13-2013, 10:19 AM
Corp Z
Corp Z's Avatar
Although more expensive, the Backyard Buddy is a great lift and able to deal with the slope I have on my garage floor (local building code). Id buy another one in a heartbeat
Old 11-13-2013, 10:28 AM
0Johnny@MTI
Former Vendor
Johnny@MTI's Avatar
i like this thread
Old 11-13-2013, 10:46 AM
hcbph
hcbph's Avatar
Default I want
Drooling almost as much as when I saw a 53 Vette with reputed history to it.
Old 11-13-2013, 02:31 PM
glava2876
glava2876's Avatar
Nice shot!
Mine will have my 79 Z/28 on top and my Corvette on the bottom too.
One thing to my advantage is that I had one side of my garage deeper, so I'll be back a little from the door
Old 11-14-2013, 12:40 AM
jdog0411
jdog0411's Avatar
Lifts are bad a$$.
Old 11-14-2013, 08:10 AM
WW7
WW7's Avatar
Well, I just made an appointment to have a garage door company come over Friday to give an estimate on how much it will cost to convert my garage door to raise up near my 12' ceiling. It now raises to the 8' level where it rolls back overhead like most garage doors do... I'll let you guys know approximately how much it cost to convert. They said I would need a different door opener then the one I have now and they would have to extend the runners .. That can't be cheap......WW
To Garage lift question
Old 11-14-2013, 02:29 PM
glava2876
glava2876's Avatar
Not sure what type you have now, but someone sent me this one;
http://www.liftmaster.com/lmcv2/prod...e-door-opener/
It attaches at one the end of the bar and on Ebay they are about $300.00
Old 11-14-2013, 02:52 PM
pmurray
pmurray's Avatar
In some cases you can also bump-out the ceiling a bit to get the car higher.
Old 11-15-2013, 12:36 PM
billsc1
billsc1's Avatar
Default What about a Quickjack B3500
Anyone using or have experience with this unit from BendPak?
http://www.bendpak.com/Shop-Equipment/QuickJack/
Quick Reply: Garage lift question
