Air cond havc issue
Old 10-15-2013, 11:42 PM
jserio
O.C.
Support Corvetteforum!
jserio's Avatar
Default Air cond havc issue
The a/c works and blows out the defroster vent. Can't get it to blow out the forward vents. Any search ideas? Thanks
Old 10-15-2013, 11:43 PM
jserio
O.C.
jserio's Avatar
Keep forgetting its a 93
Old 10-16-2013, 12:37 AM
jdog0411
jdog0411's Avatar
I'm assuming you have the electronic A/C?
This is a common issue on 96 Corvettes, so I'm not sure if this will be the same on the 93 or not. It is most likely an issue with the hvac programmer unit. Read this thread for some ideas on how to address the issue.
http://forums.corvetteforum.com/c4-g...t-blowing.html
Old 10-16-2013, 09:15 AM
Goldcylon
Goldcylon's Avatar
concur, while I dont think you have the collapsing nipples like the 96 AC programmer has you might have an issue with your AC controller.
Old 10-17-2013, 02:12 AM
Cliff Harris
Cliff Harris's Avatar
Might be the vacuum check valve. You need vacuum in the cabin to operate the various HVAC valves in the system.
Does your cruise control work? It uses the same vacuum source.
Old 10-17-2013, 03:45 AM
enventr
enventr's Avatar
Old 10-17-2013, 05:14 PM
jserio
O.C.
jserio's Avatar
My cruise is not working. Are we talking about the check valve under the fuel rail cover?
Old 10-17-2013, 05:34 PM
vetteoz
vetteoz's Avatar
With a no vac the vents will default to the defrost position
Old 10-18-2013, 05:20 PM
Goldcylon
Goldcylon's Avatar
Well thats easier than the AC Programmer to work on. Let us know so you can close out the thread
Old 10-18-2013, 07:44 PM
jserio
O.C.
jserio's Avatar
I will be working on this tomorrow. I took off the right fuel rail cover and at the back of the cover looks like a check valve but it looks metal. Is this the correct thing I'm looking at?
Old 10-18-2013, 08:01 PM
vetteoz
vetteoz's Avatar
Old 10-18-2013, 08:30 PM
jserio
O.C.
jserio's Avatar
Excellent....Thank you. love visual aids
Old 10-19-2013, 01:11 PM
jserio
O.C.
jserio's Avatar
Don't know how I missed that. Okay I took the valve off. It seems like the valve does hold suction but I'm going to replace anyway. Now the two lines from the left side that exits. The angled line ( bottom ) line holds suction. The straight line does not. Is that my problem? And if so how the hell do you find where it runs to?
Old 10-19-2013, 11:32 PM
Cliff Harris
One side goes to the cruise control servo. The other goes inside the cabin to make the HVAC valves work.
Old 10-20-2013, 03:38 PM
jserio
O.C.
jserio's Avatar
Does anyone know which is which?
Old 10-20-2013, 06:48 PM
GKK
GKK's Avatar
Check the cruise control vacuum hose just above the Battery for a leak.
My 91 Vettes cruise control vacuum line directly above the battery, had a hole in it which caused the cruise control to not operate. I replaced the vacuum line and it worked perfectly again!...
Old 10-21-2013, 01:46 AM
Cliff Harris
Follow the vacuum lines. it should become pretty obvious.
On my car the vacuum line for the HVAC goes through the firewall in the wiring harness bulkhead feedthrough behind the passenger side head. It's probably in the same place on your car.
Old 10-21-2013, 02:24 AM
jserio
O.C.
jserio's Avatar
Okay I found that upper line was to cc. I have to pick up some new hose tomorrow and see how we make out.
Old 10-21-2013, 02:07 PM
jserio
O.C.
jserio's Avatar
Alright I got the cruise control working. The A/C Flap still has not worked but I just noticed my fan is not working. Awesome .
To Air cond havc issue
Quick Reply: Air cond havc issue
