Spark Plug change interval?
Old 10-04-2013, 06:48 PM
jgalfo
jgalfo's Avatar
Default Spark Plug change interval?
I have a '86 coupe with cast iron heads and stock motor. how often do I need to change spark plugs? it's been about 12,000 so far.
I have replaced the injectors with ones from FIC and changed the distributor cap, rotor and wires when I did the plugs 12,000 ago.
I have not yet changes the one O2 sensor on the driver's side and I just turned 87,000.
not as smooth as it was under wide open throttle.
new fuel pump, filter and 40psi at the regulator
John
Old 10-04-2013, 07:10 PM
blackbear bob
blackbear bob's Avatar
Stock motor with stock plugs has a change interval of 30k.
Bob
Old 10-04-2013, 07:17 PM
jgalfo
jgalfo's Avatar
Bob
John
Old 10-04-2013, 08:24 PM
ch@0s
ch@0s's Avatar
They say you can go twice as long if you put in platinums but at this rate it will be 1,322 years before I get 60K on mine.
To Spark Plug change interval?
Quick Reply: Spark Plug change interval?
