LSx'es BEWARE of little motors with lotsa valves
One of the latest examples of what was left on the table by GM, one of the FBI gang (Lee) finished some porting on his 5.7L LT5 and dyno'ed it at Funfest in Effingham. He posted a 441 rwhp @ 7200 rpm - on a motor that cruises in traffic and idles smoothly at around 850 rpm. Eat you hearts out C5/6 drivers! Some C4s might just be wolves in sheep's clothing!
Great numbers, LEE!
Great numbers, LEE!
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
Those are great numbers for a street ride.
Great numbers, LEE!
Great numbers, LEE!
Yes, Ford took that technology and ran with it.....pushrods work as we have seen, but dual overhead cams with 4 valves/cylinder technology (especially forced induction) is just a powerful recipe and works great with higher RPM's; after all these are sports cars, right?..............perhaps costs to manufacture are the main issues.......
Seriously considering selling the Turq Monster, sans Dymags. The Dymags go to the grave with me.
May mod the 95 a bit. Stroker, brakes, exhaust, bling wheels (I-Forge Seneca's) etc.........
I want to build a copy of the 1959 Bill Mitchell Stingray. I can buy the body and associated parts from a shop in the UK. I already have a frame. I'd like to take an old FI unit and plumb it for modern fuel injectors and have the nostalgia "look". SB with at least 400hp, six speed.
Here's the car I want to build.
Great numbers, LEE!
Great numbers, LEE!
My only complaint is the LT5 is ridiculously expensive to modify. Don't give me "well it's all aluminum block and exotic", Mustang Cobras have been running aluminum blocks since 96' on a DOHC platform with tons of aftermarket support.
My 2012 mustang GT was likely seeing 410-420rwhp, on E85, and some easy bolt ons (and tune of course) and would spin to 8k. The boss 302 guys even ran those engines to 8,500rpm. Variable valve timing also helped. DOHC IS AWESOME! The only reason why I sold my GT is because the car itself was just "too" big for my taste.
Complex? Hardly.... Again, the Lt5 is far more complex (16 injectors, to kick it off), open deck decision (like the later GM NorthStar variants), odd starter placement, complexity of servicing the engine, common failure points, common gasket issues, etc. (referring to the northstars mainly).
Fords had plenty of time to refine the OHC platform, and they have.
I'll be the first to say I want an ALL MOTOR big cubic inch LT5, with heavily ported heads and cams... But when you price it out at $30k+.... My vision gets blurred... lol
I do support this thread, and again I congratulate the owner of this awesome example of an Lt5.
Received 3,043 Likes
St. Jude Donor '05
Good #s for a little "350"
Stock cams?
Strokers dont have to cost 30-40k sorry thats a straight ripoff
Problem is if you cant do it yourself or source parts youre stuck sending it to one of the few "tuners" out there $$$. Some parts are hard, if not impossible to come by. The ones that got it get what they want for them. That aspect turned me off to ownership. Fortunately when I needed something couple of good guys would always help out
If the owner of my old Z can finish getting his $ together Ill be doing a stroker for him next yr probably. Pass Ca smog, with cams
Bet its all done up right for under 10k.
Stock cams?
Cams are 225 236 415/425 intake 222 425 exhaust....
Still need to do some work on this one, tune, etc....
Size-wise, you have a point. But, too big for Corvettes? What is a C4, if not a Corvette?? The 32V V8 DOHCs are big; no doubt. But, so is their performance! Ever see a Ferrari V12? They're not a small motor, and probably wouldn't fit under the hood of a modern Corvette either! But! That isn't what sticks in people's mind when one screams by!
Cadillac has a new DOHC 3.6L V6, forced air, making over 410 hp in street trim. And, the fastest cars in the recent 1/2 mile shootout in Chicago last spring...were 4-valve DOHC V6s...
Just sayin...
