Front license plate cover ??
Old 08-28-2013, 08:04 PM
Scottys78
Scottys78's Avatar
Default Front license plate cover ??
Should the front license plate cover be painted all the way around? Or is just the face painted on a stock one? I had a crappy white one that was thin and flimsy oh and the corvette lettering looked weird. So I ordered a OEM one that I will have to get painted. Also I see the bolts that hold it on but what tool fits in there without scrching the car?
Old 08-28-2013, 08:06 PM
WVZR-1
WVZR-1's Avatar
Received 2,259 Likes on 2,022 Posts
All 5 surfaces get painted and if you've got the correct hardware you'll have no issues with the install!
Old 08-28-2013, 10:00 PM
speedycat3
speedycat3's Avatar
A torx wrench or phillips screw driver fit without scratching.
Mine had phillips head screws, but i have seen others with torx screws.
Old 08-29-2013, 01:06 AM
avigar
avigar's Avatar
You can wrap a thin piece of cloth or even masking tape on the screwdriver to keep it from scratching your plate cover.
Old 08-29-2013, 09:38 AM
Scottys78
Scottys78's Avatar
Thanks guys
Just made me think there should be a line of tools that has a rubber protective grip that would run the length of the tool.
Old 08-30-2013, 01:09 AM
JrRifleCoach
JrRifleCoach's Avatar
Location: Freedom is never more than one generation away from extinction.
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21-'22-'23-'24
....that has a rubber protective grip that would run the length of the tool.
Why not just install a piece of heat shrink on a plain ol' screwdriver.....
Old 08-30-2013, 01:48 AM
WVZR-1
WVZR-1's Avatar
That does work and quite well! Never used it on a flat-blade but on torx and phillips yes.
Old 08-30-2013, 05:44 AM
Joe C
Joe C's Avatar
Old 08-30-2013, 08:55 AM
vetteLT193
Support Corvetteforum!
vetteLT193's Avatar
The factory used torx screws, if that matters to you.
I had a folding torx all in one style tool that worked well. Looked kinda like a swiss army knife of torx. It worked well on that plate because each one was nice and thin. I'd take it off every once in a while to clean the plate well and clean behind it
To Front license plate cover ??
Quick Reply: Front license plate cover ??
