1986 Defroster Vents??
Old 08-25-2013, 10:27 AM
rrt898
rrt898's Avatar
Default 1986 Defroster Vents??
I have a 1986 coupe with the HVAC electronic controller. I have read many posts regarding the A/C blows out the defroster. All my settings work except one. My defroster blows out the dash vents toward your face. My heat can be switched from one vent to another. Also the A/C works fine on the dash vents and doesn't blow out the defroster. Just the defroster doesn't blow out on the windshield.
Thanks for any help.
Old 08-25-2013, 10:42 AM
Cruisinfanatic
Support Corvetteforum!
Cruisinfanatic's Avatar
Location: Clifton Park, NY ..............Clearwater, FL ... 85 Original Owner
broken vacuum lines. Ever had mice in your car? They snack on them
Old 08-25-2013, 04:08 PM
rrt898
rrt898's Avatar
While trying the defroster setting, now the defroster will blow strong for a few seconds then divert back to dash vents. If I remove the center bezel can I see the vac lines or does the dash pad have to come out?
thanks.
Old 08-25-2013, 05:00 PM
Cruisinfanatic
thanks.
if you remove the radio you can see the lines coming out of the controller.
Old 08-25-2013, 10:15 PM
Cliff Harris
Cliff Harris's Avatar
The C68 vacuum lines connect to the HVAC programmer, which is located above the accelerator pedal.
To 1986 Defroster Vents??
Quick Reply: 1986 Defroster Vents??
