Heater Core (Remove dash, or not?) 1989
Old 07-18-2013, 10:37 PM
BooBoo231
BooBoo231's Avatar
Default Heater Core (Remove dash, or not?) 1989
So hear I go again putting money into this car. I did some searching and half the threads say remove the dash, and the rest say you don't need to. I would obviously rather not remove it because I am affraid it may lead to squeaking in the future. Its a low mile car with very little ever touched. Just curious about some of the experiences had to see if removing the dash is mandatory....or an option. Thanks guys!
Old 07-19-2013, 12:23 AM
vetteoz
vetteoz's Avatar
http://forums.corvetteforum.com/1545958351-post9.html
Old 07-19-2013, 12:28 AM
BooBoo231
BooBoo231's Avatar
Thanks! I havent even looked under the dash yet, but I know that link will be a great help!
Old 07-19-2013, 02:42 AM
xrav22
xrav22's Avatar
2 tips for quick method
Have an 1/4 in extension for the upper far(left) bolt but instead of a 1/4 in socket fix an allen wrench into the end that little bit of space will be vital.
Also get a pack of those HELP door lock clips because your heater door will probably need one because they break easily.
Old 07-19-2013, 07:41 PM
tlvols75
tlvols75's Avatar
step 1-place the heater core in the middle of your garage.
step 2- disassemble your c4 completely and reassemble around the heater core!!!
Fozzy Bear (03-23-2023)
Old 07-19-2013, 11:12 PM
Cliff Harris
Cliff Harris's Avatar
I took off the dash pad, which allows you to see the top heater housing screws.
I bought a replacement heater core from AutoZone. The pipes didn't come out at quite the right angle so I bent them until they fit.
Old 07-20-2013, 10:41 AM
buyacar
buyacar's Avatar
[IMG][/IMG]
this is what my 1990 convert looked like while it was at the chev dealer when they did my core...ugly mess...i wouldn't want to do it myself
Old 07-20-2013, 11:36 AM
FOURSPEEDVETTE
FOURSPEEDVETTE's Avatar
DON"T TAKE THE DASH OUT! Take the passenger side seat out. Lay on your back and remove The carpeted panel on the bottom of the passenger side of the dash. Remove the ECM with 2 screws and you'll then see how easy it s to get at everything you need to from under there. Tearing all the dash and console apart is totally unnecessary on 1984-1989 C4's .
Old 07-21-2013, 04:41 AM
Cliff Harris
Since we're showing scary pictures of heater core replacement... This is what mine looked like after I drove it to work the day after I replaced the heater core. I left it apart so I could fix it easier if there was a problem (there wasn't). You don't need to take the bread loaf off. I don't remember why I did -- probably had other issues to deal with.
Old 07-21-2013, 06:31 AM
Paul Workman
Paul Workman's Avatar
I wonder if a 90 ZR-1 is much different, aside from the ECM being under the hood, next to the power brake booster (like the LT1/4 cars). I've done "a few" heater cores on different cars, and I'd rather kiss a pig than do another one... Oh, well. It's nice to know it can be done w/o removing the dash. My Z does not squeak, and I just as soon keep it that way, thank you very much!!!
Old 07-21-2013, 11:25 AM
BooBoo231
BooBoo231's Avatar
Wow thanks so much guys! I think this is going to be the best thread for heater cores yet! Thank you guys for posting those pics. I will use the "allen key" tip for sure Luckily I do have a pretty good assortment of tools. I have a bad back, so I am not looking foreward to this. I would love to pay somebody to do this, but my wallet is bad too. Haha! Thanks again for all the input.
Who do you guys think has the best heater core? I wanna do this as few times as possible. I think spending more money here for a superior part will pay off for sure.
Old 07-21-2013, 12:39 PM
65Z01
65Z01's Avatar
Cruise-In II Veteran
When I had to do the heater core in my '88 IROC-Z about 6yrs ago I got one from the local AC Delco house and it was a perfect fit.
Old 07-22-2013, 07:51 AM
AGENT 86
AGENT 86's Avatar
Few pics in this thread.
http://forums.corvetteforum.com/c4-t...ol-delima.html
To Heater Core (Remove dash, or not?) 1989
Quick Reply: Heater Core (Remove dash, or not?) 1989
