RM-6039 ls swap bellhoung...confused
From everything I have read about ls swaps in C4 Corvettes I have found that Quicktime RM-6039 allows one to reuse the zf6 with the ls engine.
Here is my confusion.
I understand there are differences between the ls and sbc.
To my knowledge you need a thick flywheel or spacer and an extended pilot bushing/bearing to use an sbc manual w/an ls.
I also understand the RM-6039 is meant for ls swaps and will not work on sbc engines.
The confusion, I am gathering parts for an ls swap and have the mentioned bellhousing.
I had a lot of clutch problems a while ago, and figured I would try using the bellhousing I got for the swap with my lt1 currently installed in the car.
I did not expect it to work, but everything bolted together. There no modification needed other then making a clutch slave bracket, and changing to a push style clutch.
What I would like to know.
Is it a ls swap bellhousing?
Am I Close on the difference between lt1/sbc and ls trasmission differences?
If my understanding is correct will I need a extended pilot bearing/bushing for the swap?
Just the housing I forgot to install the front sheet metal like plate before installing the housing. There are also no spacers.
Here is the QuickTime applications and it's like I thought, it does "ALL" so long as the ZF is used. This might help you:
http://info.prestoliteperformance.co...010_74512G.pdf
I believe you should use either the plate or the LT shim stock, block to bell-housing for a fit. You can check all of the starter pinion gaps to ring gear etc to confirm the ring gear placement and all could be good. Whose release bearing are you using? Whose clutch? Did the pivot ball come with the housing when new?
sorry forgot about this.
don't know about a LT shim stock.
I am using the clutch kit for an 88 camaro 305 5-speed
release bearing from clutch kit ^
Yes it had a clutch pivot, but I lost it and got a Mr Gasket adjustable.
I have now driven the car over 3300 miles after doing this.
