1988 35th Anniversary how much do the wheels weight?
Old 06-20-2013, 10:47 PM
muzikmanwi
muzikmanwi's Avatar
Default 1988 35th Anniversary how much do the wheels weight?
I'm sorry if this is easy to find but I'm trying to find the weight of the rim without tires on them. Thanks!
Old 06-20-2013, 11:10 PM
Chuck314
Chuck314's Avatar
I'm not going to take a wheel off my car and weigh it. LOL. But look online, it's a17x9.5 wheel.
Old 06-21-2013, 07:37 AM
65GGvert
65GGvert's Avatar
Received 3,206 Likes on 2,297 Posts
The easiest way it to take off all four tires, weigh the four wheels, then divide the total by four to get the weight of one wheel.
OR, take a look at this sticky from C4 forum to see if it contains the wheel you need.
http://forums.corvetteforum.com/c4-g...-and-info.html
Old 06-21-2013, 08:33 AM
PLRX
PLRX's Avatar
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
With or without the tire valves?
Old 06-21-2013, 10:01 AM
RollaMo-LT4
RollaMo-LT4's Avatar
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10-'11-'12-'13-'14-'15-'16-'17-'19-'20-'21-'22-'23
OEM rubber valve stems, or a good quality anodized aluminum?
Old 06-21-2013, 03:56 PM
65Z01
65Z01's Avatar
Cruise-In II Veteran
If you can't find the answer to wheel weight, weigh a wheel & tire and subtract the tire weight, Tire Rack should have tire weight specs.
Remember that if searching for the data on-line look for weight of '89 Vette wheels.
Old 06-21-2013, 05:06 PM
muzikmanwi
muzikmanwi's Avatar
I'm thinking that's what I'm going to do I kinda thought there be someone on here that might know.
Old 06-21-2013, 07:03 PM
65GGvert
65GGvert's Avatar
The wheel you wanted isn't listed on the link I posted? Tire weights are there too.
Old 06-21-2013, 10:05 PM
pkincy
pkincy's Avatar
Actually they are pretty heavy.
The 17x9.5 inch ZR1 wheels I have used have been in the 21-24 lb range. The 16x9.5 turbo look wheels from the 85-86 I used for a time on my Camaro have been about 35 lbs each. My Fikse's are in the 19-21 lb range as have been my CCWs but they are expensive and built to be light.
I expect the 88 wheels to be somewhere in between. Say 30 lbs.
The tires weigh about another 25-28 lbs and that data is pretty readily available (try Tire Rack.) Take a wheel and tire off and weigh them together and get the data for the tire weight from the mfg and subtract that.
Old 06-21-2013, 11:54 PM
65GGvert
65GGvert's Avatar
Well, if everyone is going to ignore the link:
Wheels
OE-Concepts 17x11 GS-replicas (50mm offset) - 27.4 lbs
A-mold 17x11 - 21 lbs Source
A-mold 17x9.5 - 20 lbs Source
Silver c5 rear thin spoke 18x9.5" Part #9593799 - 18 lbs Source
'88 Stock wheel 17x8.5 - 19 lbs Source
'88 Stock wheel 17x9.5 - 25 lbs Source
CCW Classic 18x12 Fully Polished - 21.6 lbs Source
CCW Classic 17x12 - 20 lbs
CCW SP500 18x10 - 20 lbs Source
CCW SP500 18x11.5 - 22.5 lbs Source
Factory Reproductions C6 z06 (black w/ machined face) 17x8.5 - 23 lbs Source
Factory Reproductions C6 z06 (black w/ machined face) 17x9.5 - 24 lbs Source
Chrome-plated stock '95 Sawblade 17x8.5 - 21 lbs Source
Chrome-plated stock '95 Sawblade 17x9.5 - 22 lbs Source
97-99 C5 OEM Wagonwheel, front - 19.2 lbs Source
97-99 C5 OEM Wagonwheel, rear - 21.4 lbs Source
97-99 C5 OEM Wagonwheel, front - 22 lbs Source
97-99 C5 OEM Wagonwheel, rear - 29 lbs Source
97-00 C5 OEM magnesium, front - 17 lbs Source
97-00 C5 OEM magnesium, rear - 19.5 lbs Source
00 C5 OEM thin spokes, front, painted, no sensors or centercaps - 17lbs Source
00 C5 OEM thin spokes, rear, painted, no sensors or centercaps - 20 lbs Source
00 C5 OEM thin spokes, front, polished - 18.08 lbs Source
00 C5 OEM thin spokes, rear, polished - 20.06 lbs Source
01 C5 OEM thin spokes, front, polished - 16 lbs Source
01 C5 OEM thin spokes, rear, polished - 20 lbs Source
01 c5 z06 OEM forged, front - 19.6 lbs Source
01 c5 z06 OEM forged, rear - 21.4 lbs Source
02-04 c5 z06 OEM cast/spun, front - 19.2 lbs Source Source
02-04 c5 z06 OEM cast/spun, rear - 21 lbs Source Source
C5 thin spoke reproduction, 18x10.5, polished - 24 lbs Source
C5 Optional Speedline 5 spoke magnesiums, 17x8.5" - 17.03 lbs Source
C5 Optional Speedline 5 spoke magnesiums, 18x9.5" - 18.93 lbs Source
C5 z06 reproduction, chrome, front - 28 lbs Source
C5 z06 reproduction, chrome, rear - 32 lbs Source
C5 z06 reproduction, chrome, front - 23 lbs Source
C5 z06 reproduction, chrome, rear - 26 lbs Source
C5 z06 motorsports, polished, front - 23.5 lbs Source
C5 z06 motorsports, polished, rear - 24.5 lbs Source
HRE 545 18x10.5, 58mm offset, clear center - 22 lbs Source
HRE 545 18x12, 74mm offset, clear center - 27 lbs Source
C5 OEM z07, front - 24.5 lbs Source
C5 OEM z07, rear - 28 lbs Source
SEC (early CCW) 17x11 3-piece basketweave - 20 lbs Source
SEC (early CCW) 17x10 3-piece basketweave - 19.5 lbs Source
Summit Legend 141 17x8", 19mm offset - 22.69 lbs Source
Tires
Michelin Pilot Sport PS2 335/35-17 - 34 lbs Source
Michelin Pilot Sport PS2 255/45-17 - 24 lbs Source
Michelin Pilot Sport PS2 275/40-17 - 26 lbs Source
Hoosier A6 335/35-17 - 28 lbs Source
Hoosier A6 255/45-17 - 24 lbs Source
Hoosier A6 275/40-17 - 24 lbs Source
Hoosier A6 295/35-17 - 24 lbs Source
Hoosier A6 315/35-17 - 27 lbs Source
Hoosier R6 335/35-17 - 29 lbs Source
Hoosier R6 255/45-17 - 24 lbs Source
Hoosier R6 274/40-17 - 23 lbs Source
Hoosier R6 295/35-17 - 24 lbs Source
Hoosier R6 315/35-17 - 27 lbs Source
Hoosier Radial Wet 275/40-17 - 24 lbs Source
Hoosier Radial Wet 315/35-17 - 27 lbs Source
Goodyear Eagle F1 GS-D3 255/45-17 - 27 lbs Source
Goodyear Eagle F1 GS-D3 275/40-17 - 27 lbs Source
Goodyear Eagle F1 GS-D3 285/40-17 - 28 lbs Source
Goodyear Eagle F1 GS-D3 315/35-17 - 30 lbs Source
Goodyear F1 EMT Run Flats 245/45-17 - 27.85 lbs Source
Goodyear F1 EMT Run Flats 285/40-17: 32.2 lbs Source
Sumitomo HTR Z 275/40-17 - 25 lbs Source
Sumitomo HTR Z 315/35-17 - 28 lbs Source
Sumitomo HTR Z III 255/40-17 - 25 lbs Source
Sumitomo HTR Z III 275/40-17 - 29 lbs Source
BF Goodrich g-Force R1 255/40-17 - 23 lbs Source
BF Goodrich g-Force R1 275/40-17 - 26 bs Source
BF Goodrich g-Force R1 315/35-17 - 27 lbs Source
BF Goodrich g-Force T/A KD 275/40-17 - 29 lbs Source
BF Goodrich g-Force Sport 255/40-17 - 28 lbs Source
BF Goodrich g-Force Sport 255/45-17 - 28 lbs Source
BF Goodrich g-Force Sport 275/40-17 - 29 lbs Source
Continental ExtremeContact DW 255/40-17 - 23 lbs Source
Continental ExtremeContact DW 255/45-17 - 25 lbs Source
Continental ExtremeContact DW 275/40-17 - 25 lbs Source
Firestone Firehawk Wide Oval 255/45-17 - 29 lbs Source
Firestone Firehawk Wide Oval 275/40-17 - 29 lbs Source
Firestone Firehawk SZ50 EP RFT with UNI-T 245/45-17 - 29 lbs
Firestone Firehawk SZ50 EP RFT with UNI-T 275/40-18 - 34 lbs
Goodyear GS-C 275/40R17 - 26.4 lbs Source
Hoosier A3S03 275/40-17 - 12 lbs Source
Hoosier A3S03 315/35-17 - 15 lbs Source
Hoosier A3S03 305/30-18 - 16 lbs Source
Goodyear ZR "S" Rains 275/40-17 - 28 lbs Source
Goodyear ZR "S" Rains 315/35-17 - 30.5 lbs Source
Goodyear GS CS, shaved to 6/32", 275/40-17 - 25 lbs Source
Goodyear GS CS, shaved to 6/32", 315/35-17 - 28 lbs Source
Goodyear F1 GS SC 265/40-17 - 23 lbs Source
Goodyear F1 GS SC 265/40-18 - 27 lbs Source
Goodyear F1 GS SC 275/40-17 - 24.5 lbs Source
Goodyear F1 GS SC 295/35-18 - 25.5 lbs Source
Goodyear F1 GS SC 315/40-18 - 28 lbs Source
Bridgestone Potenza S02 255/40-17 - 25 lbs Source
Bridgestone Potenza S02 275/40-18 - 27 lbs Source
Bridgestone Potenza S02 285/30-18 - 29 lbs Source
Bridgestone Potenza S02 285/30-18 - 30 lbs Source
Bridgestone Potenza S02 295/30-18 - 30 lbs Source
Bridgestone Potenza S02 295/35-18 - 29 lbs Source
Kumho Ecsta 711 245/45-17 - 28 lbs Source
Kumho Ecsta Supra 245/45-17 - 29 lbs Source
Kumho Ecsta MX 245/45-17 - 32 lbs Source
Kumho Ecsta Victoracer 700 245/45-17 - 26 lbs Source
Kumho Victoracer V700 265/45-16 - 26.9 lbs Source
Kumho Victoracer V700 315/35-17 - 30.5 lbs Source
Kumho Victoracer V700 255/40-17 - 26 lbs Source
Kumho Victoracer V700 275/40-17 - 27.8 lbs
Kuho Ecsta Supra 265/40-17 - 30 lbs Source
Kumho Ecsta MX 275/40-18 - 36 lbs Source
Kumho Ecsta V700 285/30-18 - 25 lbs Source
Kumho Ecsta V700 315/35-17 - 29.7 lbs Source
Kumho Ecsta V700 335/35-17 - 31.1 lbs Source
Kumho Ecsta V700 275/40-17 - 26.3 lbs Source
Kumho Ecsta Supra 295/35-18 - 30 lbs Source
Kumho Ecsta MX 275/35-18 - 20 lbs Source
Kumho Ecsta MX 295/35-18 - 31 lbs Source
Kumho Ecsta V700 305/30-18 - 26 lbs Source
Kumho Ecsta V710 315/35-18 - 28 lbs Source
Kumho Ecsta V710 315/35-17 - 27.8 lbs Source
Kumho Ecsta V710 275/40-18 - 25.8 lbs Source
Kumho Ecsta V710 295/40-17 - 26.9 lbs Source
Kumho Ecsta V710 265/45-16 - 25 lbs Source
Kumho Ecsta V700 335/30-18 - 30 lbs Source
Kumho Ecsa ASX 245/45-17 - 27 lbs Source
Kumho Ecsta ASX 275/40-18 - 30 lbs Source
Kumho Ecsta XS KU36 265/40-16 - 28.2 lbs Source
Kumho Ecsta XS KU36 315/35-17 - 32.4 lbs Source
Kumho Ecsta XS KU36 335/35-17 - 34.4 lbs Source
Kumho Ecsta XS KU36 255/40-17 - 25.1 lbs Source
Kumho Ecsta XS KU36 275/40-17 - 27.9 lbs Source
Kumho Ecsta XS KU36 285/40-17 - 30.2 lbs Source
Kumho Ecsta MX KU15 255/40-17 - 23.9 lbs Source
Kumho Ecsta MX KU15 275/40-17 - 27.2 lbs Source
Kumho Ecsta MX KU15 285/40-17 - 29.1 lbs Source
Avon Tech M550 A/S 245/45-17 - 29 lbs Source
Avon Tech M550 A/S 275/40-18 - 34 lbs Source
Avon Tech M500 245/45-17 - 28 lbs Source
Avon Tech M500 275/40-18 - 32 lbs Source
Continental ContiExtremeContact 245/45-17 - 24 lbs Source
Continental ContiExtremeContact 275/40-18 - 25 lbs Source
Kumho Ecsta MX 245/45-17 - 25 lbs Source
Kumho Ecsta MX 275/40-18 - 29 lbs Source
Pirelli PZero Nero M&S 245/45-17 - 24 lbs Source
Pirelli PZero Nero M&S 275/40-18 - 29 lbs Source
BF Goodrich G-Force T/A KDW 245/45-17 - 28 lbs Source
BF Goodrich G-Force T/A KDW 275/40-18 - 32 lbs Source
Goodyear Eagle F1 GS 245/45-17 - 25 lbs Source
Goodyear Eagle F1 GS 275/40-18 - 28 lbs Source
Kumho Ecsta MX runflat 245/45-17 - 32 lbs Source
Kumho Ecsta MX runflat 275/40-18 - 35 lbs Source
Continental ContiSportContact 2 245/45-17 - 25 lbs Source
Continental ContiSportContact 2 275/40-18 - 26 lbs Source
Dunlop SP Sport 9000 245/45-17 - 26 lbs Source
Dunlop SP Sport 9000 275/40-18 - 29 lbs Source
BF Goodrich G-Force T/A KD 245/45-17 - 27 lbs Source
BF Goodrich G-Force T/A KD 275/40-18 - 31 lbs Source
Goodyear Eagle F1 GS-D3 245/45-17 - 25 lbs Source
Goodyear Eagle F1 GS-D3 275/40-18 - 28 lbs Source
Michelin Pilot XGT Z4 245/45-17 - 26 lbs Source
Michelin Pilot XGT Z4 275/40-18 - 30 lbs Source
Bridgestone Potenza RE050 245/45-17 - 26 lbs Source
Bridgestone Potenza RE050 275/40-18 - 28 lbs Source
Bridgestone Potenza S-03 Pole Position 245/45-17 - 28 lbs Source
Bridgestone Potenza S-03 Pole Position 275/40-18 - 32 lbs Source
Goodyear Eagle F1 Supercar 245/45-17 - 24 lbs Source
Goodyear Eagle F1 Supercar 275/40-18 - 27 lbs Source
Wheels/Tire Combos
17x8.5 polished Sawblades with 255/45 Firehawk SZ50 - 47.1 lbs Source
17x9.5 polished Sawblade with 285/40 Firehawk SZ50 - 49.3 lbs Source
C5 97-00 OEM Magnesium with Nitto 275/40-17, 1/2 tread, front - 45 lbs Source
C5 97-00 OEM magnesium with Yokohama AVS Sport 295/35-18, rear - 50 lbs Source
2006 C6 z06 stock wheel/tire, front - 51 lbs Source
2006 C6 z06 stock wheel/tire, rear - 56 lbs Source
Old 06-23-2013, 03:32 AM
muzikmanwi
muzikmanwi's Avatar
I had tires put on them today so what better time to weigh them and the answer is 26.2 lbs. Just the wheel I forgot to weigh the center cap.
To 1988 35th Anniversary how much do the wheels weight?
Quick Reply: 1988 35th Anniversary how much do the wheels weight?
